Serial EEPROM interfacing
I wish to interface at45db081d-ssu-2.5(serial EEPROM with SPI) with an ARM processor. I would like some tips to use EEPROM.
The procedure I follow is :
->SPI enable
->Erase chip
->write
->read
But when i read the data i get garbage .I think there is some trouble in reading or writing.Can i get a pseudo code for any SPI EEPROM device.
  • Sample code i am referring :
    // AT45DB081D - Buffer Write
    _spi_start();
    _spi_sendbyte(0x87); // Command - Write Buffer 2 // long data type
    _spi_sendbyte(0x00); // Address - x x x x x x x x
    _spi_sendbyte(0x00); // Address - x x x x x x x B
    _spi_sendbyte(0x0E); // Address - B B B B B B B B
    _spi_sendbyte(0x00); // ??? 1 Dummy Byte ???
    _spi_sendbyte(0x12); // ?????? ????
    _spi_sendbyte(0x23); // ?????? ????
    _spi_sendbyte(0x34); // ?????? ????
    _spi_sendbyte(0x45); // ????????? ????
    _spi_sendbyte(0x56); // ????? ????
    _spi_stop();
    // AT45DB081D - Buffer Read
    // (D1H for buffer 1 or D2H for buffer 2)
    _spi_start();
    _spi_sendbyte(0xD1); // Command - Read Buffer 1
    _spi_sendbyte(0x00); // 1 Dummy Byte
    MEMbuff[0] = _spi_readbyte(); // ?????? ????
    MEMbuff[1] = _spi_readbyte(); // ?????? ????
    MEMbuff[2] = _spi_readbyte(); // ?????? ????
    MEMbuff[3] = _spi_readbyte(); // ????????? ????
    MEMbuff[4] = _spi_readbyte(); // ????? ????
    _spi_stop();
