I am training myself to use MDK5 on an ST Micro 32F429IDISCOVERY board, which uses the STM32F429ZI, Cortex-M4 processor. I found a cheat sheet on the Keil web site entitled "STMicroelectronics: Cortex(TM)-M4 Training STM32F429" at:
- http://www.keil.com/appnotes/files/apnt_253.pdf
The sheet claims to have been written in 'Winter 2013' and to be based on MDK4 (pg 3). I have made it to page 11 and found it to exhibit most of the claimed features with the following exceptions:
1. On pg. 6, after you have built, loaded, and executed the 'Blinky' project, the LEDs LD3 and LD4 are supposed to blink. On my board, they do not, even though I can step through the main control loop and see calls to LED_On () and LED_Off(num) being executed.
2. On pg. 10 it teaches you how to load global variables into the Logic Analyzer and display them in in a manner resembling a scope trace. I can get the variables to register, but no values are displayed (not even 0).
3. On pg. 11 it walks you through testing the printf feature, and view "Hello World" in the Debug Viewer window. It attributes this to the: printf("Hello World\n\r");
statement near line 100 of Blinky.c.
The version of Blinky.c that I installed with MDK5 has no printf statements whatsoever. The app note has an accompanying set of project files which MDK5 tells you were designed for MDK4 and which cannot be built without installing "Legacy support", but that Blinky.c contains no printf statements either.
Before I dive any deeper, I am wondering:
1. How many Blinky projects for the 32F429IDISCOVERY board exist? Where are they located? Did I use the wrong one? Are there multiple versions of the 32F429IDISCOVERY board with incompatible pinouts?
2. Is there some additional trick to get the Logic Analyzer to work? As suggested by the cheat sheet, I tried exiting and re-entering debug mode and cycling power the the Discovery board. They made no difference.
3. Where have all the printf's gone?
My thanks for any insights.
Absent any support, I have continued to dig into this project myself. According to the schematic I downloaded for my Discovery board, only 2 LEDs: LED3 & LED4 are directly soldered to GPIO ports PG13 and PG14 of the processor and under program control. When I stepped through the initialization routine and monitored the configuration and data registers of GPIOG I could see no changes whatsoever. The initialization is controlled by an array of struct whose origins are difficult to find, but I do find the following definition in file LED.c:
const GPIO_PIN_ID Pin_LED[] = { { GPIOD, 12 }, { GPIOD, 13 }, { GPIOD, 14 }, { GPIOD, 15 } };
from which I infer this module assigns 4 LEDs to port D and none to port G.
So either I have the wrong board, or loaded the wrong Blinky application, or Keil released this eval software without testing it on actual hardware.
I attempted to address this issue at the source: inside LED.c, but it appears to be write-protected. I have as yet found no way to track it down on my disk drive.
Does anyone know how?
sounds that way. GPIOD sounds ARM. the '51 'speaks' Port0, Port1, ....
BTW with the F429 you would, probably, be better off at the SILabs forum http://community.silabs.com/
While Bob comes by here occasionally, usually when things are on fire, you might be better served by just emailing him directly, his address is on the application note.
This is a USER forum, not an official Keil support venue, they have a direct email address, which I believe is support@keil.com http://www.keil.com/support/
The LED's you describe are for the STM32F4-DISCO, the board you have is the STM32F429I-DISCO
The printf() stuff is not in the blinky from the app note, or for that matter the general blinky examples, so there's definitely an issue with what's being provided in the ZIP vs the app note. For printf() stuff you'd be better to look at the retarget.c/serial.c type files, and use the ITM_SendChar() functions to send characters to the SWO/SWV interface.
http://www.keil.com/appnotes/docs/apnt_261.asp http://www.keil.com/appnotes/docs/apnt_230.asp
sorry, missed the 'ARM' however this show how important full part numbers are, SILabs also make a ...F429 (the rest of the numbers are different from the ST)
Erik,
I always put the full P/N in the first line, but you are correct that in forums that are not HW-specific, I should have put it in the subject line, no matter how long that would make it (apologies).
All,
I have been using Keil debuggers since 1996, mostly with 8-bit products and know how to debug with far less than the Cadillac features I see in MDK5. If I never get the printf feature to work, that will only slow me down a bit.
However, if I can't get the Blinky example app to blink my LEDs, that is a show stopper.
I have been reluctant to use freebie examples on the claim they get you up and running faster than writing the first application from scratch because if the freebie sample has a bug it in, it is far more difficult to troubleshoot than my own code because the freebie code has a massive amount of superfluous complexity built into it having nothing to do with my task.
So, it still looks like the problem is my app is talking to the wrong ports to drive my LEDs, as suggested by the LED.c file I see in the code window of MDK5.
When I look at the directory structures under c:\keil_v5 created by the MDK5 installer (and enhanced by me with more code from the Keil app notes) I find 8 files named LED.c. They are deeply nested in the structure (some up to 9 levels) and to display them clearly I need access to more HTML tags than this forum will allow. I have uploaded my illustration file here:
- my.execpc.com/.../LedDrivers02.html
and request you view it with a browser while I ramble on.
I extracted the code that initializes the LEDs from each file (concerning myself only with those related to the STM32F4) and tacked that code to the right.
Here you can clearly see that only the LED.c under the Blinky and RTX_Blinky examples of Keil app note initialize port G. The other 4 address only port D.
Under directory:
C: +--Keil_v5 +--ARM +--Examples +--Boards +--ST +--STM32F4-Discovery +--Blinky-KeilAppNote253 +--Blinky
there is a file called Blinky.uvprojx, which I took to be a project file. When I load that file into MDK5, I get the window documented at the bottom of the web page. This is clearly not the LED.c file in the Blinky directory. Furthermore I cannot edit it, so infer it is write- protected. meaning it is probably one of the 3 files I have marked in red (unless it is not stored under c:\Keil_v5) in the directory structure.
Getting back to my original question...
It would be nice to be able to track this file to its actual storage location and I want to know if one can do that with MDK5.
I'm leaving this on the forum because I think it's a question of broader interest. The problem belongs to another class of program complexity I call "intermodule dependencies". As far as I know there are no generally-accepted standards reining in the spaghettification of an application in this domain, so styles are still specific to the individual programmer. (Shame that is.)
If none of you knows the answer, I will then send it on to Mr. Boys.
When you open a project, you can look at the properties for the individual files in the project. That gives you information about the path of the file and any special build options.
CORRECTION!
Despite all my pre-cautions, I still managed to get lost in that directory jungle and loaded the wrong app. The Blinky app that comes with App Note 253 MIGHT be functional, but will not build under MDK5 without installing "Legacy Support" as it was created with MDK4.
I can't install "Legacy Support" myself and the guy who can was out to lunch, so while waiting I tried using the "20) Creating your own project from scratch: Using Blinky source files" chapter of the App Note 253 PDF, but instead of creating an empty project, pulled in the source files from the App note 253 .zip module.
App Note 253 itself was written for MDK4 and there are subtle differences in several of the windows, but I managed to guess my way through all of them, build, load, and run the Blinky example without further tweaking of the source files. (It works!)
So, while I would still like to know how to identify the location of a file if it's not in the project directory, this gap is not holding me up any more.
Thanks for your hints!
