printf outputs wrong result when do multiplication
volatile unsigned char a;
a = 3;
printf("%u\n", a * 100);
The output is 11264. Why?
Any reply would be greatly appreciated.
  • What compilation options do you use.
    The C51 compiler can generate code either in compliant mode, where it always performs integer promotion. But it can also generate code without integer promotion, which means that you need to explicitly cast variables if you want to upgrade the variable to sizeof(int).
    16-bit arithmetic is just quite expensive on a C51 processor, because of the instruction set.
  • A footnote: 3*100 = 300 decimal or 0x12c.
    11264 decimal is 0x2c00.
    So if 3*100 is computed as an 8-bit expression, then the argument to printf() is 0x2c while printf() expects to pick up two bytes and manages to find 0x2c and 0x00.
    With integer promotion enabled, then 3*100 will always be computed with at least 16-bit precision and a 16-bit value will be send to printf() - so the correct answer will be printed.
  • Hi Per Westermark,
    Thanks for you quick reply.
    I check the option Enable ANSI integer promotion rules and it is enabled. If I disable it, the output is the same. It seems that Keil complier does not promote varible a or constant 3 to an integer.
    If I change code to this:
    printf("%u\n", (unsigned int)a * 100);
    or
    printf("%u\n", a * (unsigned int)100);
    The result is correct.
  • If C51 doesn't do integer promotion and sends int-size values to printf() even with integer promotion on, then I would recommend you to send a message to Keil support.
