read write on code memory in 8051 using C
I am using P89v51rd2.
I want to store only one variable in the code memory,
so that it is stored permanently. (say a=9999; max)
I want to update this frequently in the program, and read when
required.
can anyone provide me the code for the same ?
thank you...
  • I want to store only one variable in the code memory .... I want to update this frequently in the program, and read when
    required.
    not a good idea, the flash memory has a limited 'life' (I do not recall your chip, but typically 1000-10000 erases.
  • ohh. what can I do then ?
    I am working on the project of counting the number of
    objects passed through when the get manufacture.
    I want to recall the count if the power goes accidentally
    during the operation.
    what is the efficient way to do this ??
    thank you....
  • External EEPROM or Battery backed SRAM.
    Consider also a different processor choice which has said.
  • Or F-RAM. They can be found with a number of different interfaces suitable to microcontrollers.
  • actually I have almost done with the this project...
    Is there any other alternative besides adding hardware?
    Can I do with software ?
  • Check IAP functions of your uC, if any.
    And you should learn about features of Flash and how to wear-balance it.
  • yes.There is IAP programming feature available..
    but flash has limited time programming facility , am I right ?
    how can I overcome this, since the variable is need to be updates frequently
    in the program ?
    can you elaborate please?
  • You overcome it by not using the flash. The flash normally have too large pages to be really meaningful for wear-leveling.
    But how can you be almost done with the project, without having covered the required hardware? Was saving data in non-volatile storage a late addition to the requirements?
  • Is't only the additional feature I am providing.
    It was not in my requirements.
    Is it possible now?
  • Yes it is possible - it's just a question of your "frequently" and how much you care. I _think_ the endurance is 10000 writes - and a sector erase size of 128 bytes. One question is how quick a write or erase is - it can sometimes be a show-stopper. You have to locate the relevant datasheets and figure out exactly what is documented about your chip.
    So - how many 128 byte sectors can you dedicate to your counting? And how clever can you be using them? That will control how fast you reach 10k write/erase cycles for each 128 byte sector. Note that the power may fail when you write your data, so you need to store your data in a way that you can recover from such a write or erase failure. So you can't just consider two bytes as a good integer for storing a value 0..65535.
    EEPROM often supports 1 million write cycles and counted for single bytes or maybe small 16-byte sectors.
  • thanks for the reply Per.
    I don't think that will be useful
    because my 'frequently'= about 2000 per day.
    and the data is 2 byte which is going to be updated.
    thanks for your co operation...
    It definitely added my knowledge...
  • because my 'frequently'= about 2000 per day.
    how much flash do you have left?
    how many years must your device function
    with a 'walking write', you can get about a million writes (500 days) per 256 bytes of flash.
    does your device give a 'power down interrupt?
  • Note that if counting every item to flash, then it isn't needed to store two bytes, i.e. 1878, 1879, 1880, 1881, ...
    Each save would basically just be a +1, +1, +1, +1 in relation to a base counter value.
    So a flash sector could contain:
    1878, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, 1, 2, 3, 4...
    and unused bytes remains at 0xff. This means a 128 byte sector can spend maybe 4 bytes for initial value and inverse of initial value and then have room for 128-4 counts.
    If the flash supports multiple writes of the single byte, then a 128-byte sector could fit 1000+ counts for a single erase cycle.
    Then there exists processors that computes a CRC with every sector, setting the limit at one single write to a sector before it needs to be erased.
    But if the hardware can't handle a dropping supply voltage correctly, then the firmware needs to be able to detect scrambled data and be able to figure out with a reasonably high safety margin how far it had made it before a flash write goofed and scrambled data. And that requires that there are some form of redundancy in the storage in the form of check bits or similar.
  • Checkpointed write transactions to non-volatile memory are used on some systems that lack adequate power-fail notification. A "record" is either written in its entirety before power fails or a partial write is "rolled back" during power-up recovery.
    Some keywords to Google.
