hi....i am just starting with ARM microcontrollers........ i want to make a program so that i can monitor a pin like P0.8 and if its high then LED should glow on P0.22
here is pseudocode for it
#include <LPC21xx.h> #define led (1<<22) #define sw (1<<8) int main (void) { PINSEL0=sw; IODIR0=0xFFFFFFF; if (sw == 1)
IOSET0 = (1<<22); else IOCLR0 = (1<<22); }
May be you want a while(1) loop there, in case you blow past the test in a millionth of a second.
its just rough code...can u correct the code sir?
He already tried that. You refused to listen. So why should anyone continue to try?
And BTW: how do you suppose people help you correct your code, if you can't even be bothered to explain what you believe is wrong with it?
well....i think that code is fundamentally wrong...i tried what he said on my dev board but it didnt worked
Do your teachers not provide you with guidance, or notes?
I have no idea what board you have, and I'm not much into NXP, but this would seem to be a more sensible solution. Note the use of PRE tags for source code, per the "Tips for Posting Messages"
#include <LPC21xx.h> #define led (1<<22) // Led is bit 22 #define sw (1<<8) // Switch is bit 8 int main (void) { IODIR0 &= ~sw; // Set as inputs IODIR0 |= led; // Set as outputs while(1) { if (IOPIN0 & sw) // Check switch state, reflect to led IOSET0 = led; else IOCLR0 = led; } }
well i am learning by myself..... i am using LPC2129 board...
this code is not working
That's a chip, what board is it on, who makes it? Provide a cite for schematics, documentation, etc.
If that's what you think, what possessed you to write fundamentally wrong code?
Or more to the point: why didn't you just steal better code from somewhere else?
