how to get the day of the week and month of year
sirs.
I want to know how can i give a month of year and day of month. and i what to return the month and day for some time later (ie 60 days later). if it is on a sunday it must go to Monday
my friend asked before but nobody helped him with the correct answer. we now need a good response very quickly. can someone help
I am hope that there is someone smart enough to give us the correct answer.
  • they did not tell me you have seen them.
  • you have been told in 3 different ways how to do it in your previous identical posts so why do you not just change your post to "give me the friggin code", not that that will result in anything. This is not a "give code forum" it is a "help you to write the code forum"
  • Even though the question has been repeated several times, there doesn't seem to be any more detail.
    When asking vague questions consider that others don't have information that might only be apparent to you.
    What processor is being used?
    What board is it on?
    What method are you using to represent time?
    Do you have an RTC?
    What code, or framework, have you already developed?
    How is that working, or not working?
    Can you just get your test code to advance a single day, hour or minute?
    How does that work?
    What specific area of the problem are you stuck on?
    If you said ALL of it, then look at your programming skill, and review the architecture of your processor and system more thoroughly.
