I have a problem with the configuration of Keil microvision 5 with the STM32L Discovery Development board. I set up a template project according to the tutorial present in this page fabioangeletti.altervista.org/.../ that is however for a different version of STM32 board (STM32F0 Discovery). When I click on the build all button, I receive a lot of error messages. Following is a part of the errors list (176 in total). Any suggestion on how to fix it? Thanks in advance.
.\obj\Project.axf: Error: L6200E: Symbol DAC_IRQHandler multiply defined (by startup_stm32l1xx_md.o and startup_stm32l1xx_hd.o). .\obj\Project.axf: Error: L6200E: Symbol DAC_IRQHandler multiply defined (by startup_stm32l1xx_mdp.o and startup_stm32l1xx_hd.o). .\obj\Project.axf: Error: L6200E: Symbol DAC_IRQHandler multiply defined (by startup_stm32l1xx_xl.o and startup_stm32l1xx_hd.o). .\obj\Project.axf: Error: L6200E: Symbol DMA1_Channel1_IRQHandler multiply defined (by startup_stm32l1xx_md.o and startup_stm32l1xx_hd.o). .\obj\Project.axf: Error: L6200E: Symbol DMA1_Channel1_IRQHandler multiply defined (by startup_stm32l1xx_mdp.o and startup_stm32l1xx_hd.o). .\obj\Project.axf: Error: L6200E: Symbol DMA1_Channel1_IRQHandler multiply defined (by startup_stm32l1xx_xl.o and startup_stm32l1xx_hd.o).
Not enough information to list image symbols. Not enough information to list the image map. Finished: 2 information, 0 warning and 176 error messages. ".\obj\Project.axf" - 176 Error(s), 0 Warning(s). Target not created
Pick ONE startup_stm32xxx.s file which is suitable for the chip you are using, ie memory, feature set, etc.
"Error: L6200E: Symbol DAC_IRQHandler multiply defined (by startup_stm32l1xx_md.o and startup_stm32l1xx_hd.o)"
That message seems perfectly clear and explicit - which part don't you understand?
It is telling you that you have two files - startup_stm32l1xx_md.o and startup_stm32l1xx_hd.o - which both contain a definition of DAC_IRQHandler
You need just one or the other - but not both!!
"according to the tutorial present in this page..."
Have you asked the author of that page?
