Suppose I an writing a single pin repeatedly like:
LPC_GPIO->SET[0] = 1; LPC_GPIO->SET[0] = 0; LPC_GPIO->SET[0] = 1; LPC_GPIO->SET[0] = 0; // interrupt comes here LPC_GPIO->SET[0] = 1; LPC_GPIO->SET[0] = 0;
If no optimization is used then all instruction will be converted into load, mov & store. Load, mov & store is atomic so cannot be interrupted.
Bit if I use optimization, then compiler will load address on first line only & then it keep STROE instruction only for rest of instruction as address has already been loaded.
What if now interrupt comes as I marked & in interrupt some other address register is loaded. When control comes out of ISR , what will happen as new address has been loaded
Then that interrupt handler is totally FUBAR.
What a useful response (palmface).
When an interrupt occurs it is normal for the interrupt service routine to restore all registers such that the code which was interrupted carries on as if that interrupt had not occurred.
Whether the application is coded in C, assembler or whatever else, this is still the normal behaviour.
