No Algorithm Problem
I am trying to resurrect an MCB2100 from the shoebox where it has lived for the last several years, using the uv4 suite.
Even after adding the algorithm per the various instructions here for doing so, I still get this error. I tried both the IAP and IAP2 algorithms, and double-checked the target settings to make sure the correct device was selected. I also verified the memory space settings in the MCB2100 literature.
I can get the Blinky project to run on the device using the debugger and ticking the "Download to Flash" option in the debugger settings. I just can't get it to flash download properly from the IDE.
Thanks in advance.
Load "C:\\Keil\\ARM\\Boards\\Keil\\MCB2100\\Blinky\\RAM\\Blinky.axf"
No Algorithm found for: 40000000H - 40000387H
Erase skipped!
