warning C102
why differentiates the compiler in assigning a "pointer to const" an adress directly or via a function call?
void test (const uint16_t *cpui16)
  if (*cpui16 == 17)
    return;
void test1(void)
      uint16_t  ui16 = 9U;
      uint16_t *p    = &ui16;
const uint16_t *cp   = &ui16; //warning C102:
  test(&ui16);                //no warning
  test(p);
  test(cp);
And why marks the compiler a warning and the manual an error?
Compiler
warning C102: '=': different const/volatile qualifiers
Manual
*** Error C102
operator: Different const/volatile Qualifiers
I cannnot imagine a potential problem with
Can anybody give me a hint?
Best regards
Jürgen
  • I cannnot imagine a potential problem with
    It's because "cp" is a pointer to a constant, but what it's pointing at (ie, &ui16) is *not* constant. "cp" is declared const, but its usage is volatile const.
    The function call
    test(cp)
    does not cause a warning because the declaration of "cp" matches the function declaration.
    Change your code to
    volatile const uint16_t *cp = &ui16;
    and the first warning will go away, but you'll get one at test(cp).
  • Thank you for your answer.
    I don't understand why
    and I don't understand the meaning. Can you please give me an explanation or a link to one?
    I tried your suggestion but it did not work.
    gives the same error message although I think there is no risk in reading a variable via a const pointer.
    By the way, all function calls don't produce an error message.
  • I tried your suggestion but it did not work.
    Never mind that, the warning may be compiler specific and it's a bad example anyway; there *is* a difference between "const uint16_t *x" and "volatile const uint16_t *x".
    And you do understand what the qualifiers mean, right?
    const uint16_t *x; // The value cannot be modified by code nor anything else.
    volatile const uint16_t *y; // The value cannot be modified by code,
                                // but may be modified by something else,
                                // ie. an interrupt or hardware or another task.
    uint16_t *x; // The value can be modified by the code and, with the exception
                 // of aliasing, won't be modified by anything else.
    Using the qualifiers incorrectly can cause unexpected side effects.
    Your example:
          uint16_t  ui16 = 9U;
    issues a warning because you've told the compiler that the value of the referenced address will never change, but you've assigned it an address that *can* change.
    For example:
          uint16_t  ui16 = 9U;
    ui16 = 15;
    The last statement causes the dereferenced value of "cp" to change, which violates the agreement your code has made with the compiler. That is why you get a warning.
    And it deserves a warning because it creates a situation where the program may work as expected, or it may not work as expected, or it may work as expected some of the time.
  • Oh yes, I think I got the point.
    I know the qualifiers 'const' and 'volatile' and I tried to tell the compiler, that I don't want to change the value of the variable ui16 which the pointer cp dereferences via this pointer (as lint suggested).
    But what I really did was telling the compiler that pc dereferences a variable that would not change ever.
    And that is a difference as I see now.
    Thanks again for your kind effort although I don't see how I can satisfy lint (which suggested to declare cp as pointing to const) and the compiler (which says the variable cp dereferences isn't really const)
