Kiosk provider seeking an 8051 assembly language developer to patch firmware to: * Add two i2c commands: 1-turn on 2-turn off Notes: 1. Device has pre-existing soft power control. 2. Device has pre-existing operational I2C interface. 3. Current firmware is available only as ROM image. 4. We -possibly- have some C source code for the 8051-based controller, but it is not configured for the product, nor includes past manufacturer provided customizations. It is probably mostly useful as a reference tool. Deliverable Requirements 1. ROM image: a. With new I2C on/off command functionality. b. Upon boot, the device must start in the existing on state. c. All existing functionality must still be operational. d. Provided in the same ROM-able Intel hex format the original firmware image was supplied in. 2. New functionality in deliverable #1 must pass 100 I2C command off/on test cycles. 3. Assembly language listing for deliverable #1, with descriptive comments documenting changes. 4. Deliverables must be provided within 6 business days from when both parties agree to commencement of work. Available Resources We can provide for the duration of the work: * One controller board for development/testing. -and- * One end-product module which uses the controller board. Work Quotation Please e-mail: * Your all-in fixed price for the work. * Relevant qualifications. * The option of partial payment mid-way through project requires two strong references. Otherwise, payment is upon receipt of the required deliverables.
Ok. I am ready to do it. Your contact details?
Couldn't possibly quote fixed-price for that!
And yet you wish to remain anonymous?
We have no idea what this system is (other than the vague mention of a "kiosk provider") or does.
Maybe it is trivially simple, and can be reverse-engineered from a ROM image alone in a week.
More likely not...
(I prefer to remain an omnibus)
More likely not... May be Tom Cruise(MI:Infinite) or Daniel Craig(James Bond - RE: Reverse Engineering) can do it.
~ LOOP HOLES ~ We dont even know which specific chip has been used? Whether it has on-chip I2C? What code is already written?
No assurity of existing Code.
Does any body have any idea of who some one is going to generate the assembler code, (or even C for that matter - if you are Einstein, i dont have any problem) from the ROM image in 6 days (forget writing the patch code)?
"We dont even know which specific chip has been used? Whether it has on-chip I2C? What code is already written?"
Neither do we know the size of this "ROM image".
A couple of hundred bytes shouldn't be hard to disassemble (assuming no deliberate obfuscation)...
c. All existing functionality must still be operational. After reading this, i can only hope and have my fingers crossed that code is less than few hundreds of bytes.
I am a bit worried about how will the contractor differentiate between the const strings/arrays from the actual code? (given only the hex)
I'm interested.
How can I PM the guy?
Richard Marshall BEng(Hons)
You basically need to do a 100% code coverage simulation based on the received hex file, to catch exactly what is code and what is data.
A raw disassembly will normally pick up false code unless it supports multipass analysis to try to catch jumps. But code that has computed jumps aren't easy to analyze - how many jump destinations are possible?
Comm-on Per. He can do the reverse-engineering. So what if he cant engineer it!! And what are forums for after all? We are here to do it.
Have you ever heard of ida pro? there are quite a number of tools that can reasonably accurately detect code and data when creating a disassembly.
And yes, I got the LED flashing. No thanks to the respondents here for that one.
Dear Richard, You have any idea why people are not taking you seriously??
experts over here are even not attempting and you are readily saying "YES" to it? (astonished)
Dear "you just dont get it DUDE!!!"
Well, it's their loss.
Why do you pretend to be someone else? It is obvious from what you have posted before under your real name to know who you are.
Maybe it is you who "doesn't get it".
In that case,....
On-your-marks, Get-set,.... Go!!!
Good luck.
It doesn't look like you're going to be crushed in the rush of others running to win this particular deal...
Even more luck is required if he doesn't provide contact details.
But I'm here. Ready, eager and waiting for somebody to come knocking.
Now to get my consultancy business fully operational.
Anybody know how to make a web site?
