hi to all, i am creating a something like file explorer with lpc1788,with keil v5.11a as compiler. keil flash file system work correctly and good when i want read any file from memory card,but when i want write to it,some thing happened that surprised(and confused) me!!!! please look at on function of my code(that will copy a file from usb flash disk to memory card) :
unsigned char Copy_File_Flash_To_Sd(char *Dest,char *Source) { FILE* myDest; FRESULT fResult; BYTE res = 0x00; char copyRes = 1; UINT tmp = 1; FIL mySource; //checking that source file exist or no if(f_stat(Source + 4,0x00) != FR_OK) return 0; myDest = fopen(Dest,"w"); //checking for errors when opening file if(myDest == NULL) { char i = 0; //re initlie flash fs(try in three time) for(i = 0;i < 3;i++) { if(finit(0) == 0) break; } //re open file myDest = fopen(Dest,"w"); if(myDest == NULL) return 0; } //opening source file for read(+4 skim "U0:\" part of path) if(f_open(&mySource,Source + 4,FA_READ) != FR_OK) { //closing opened file in sd card fclose(myDest); //reporting that proccess was faild return 0; } //creating a delay msDelay(50); //hitherto all thing is true //reading all byte of source file while(1) { //reading one byte from flash disk fResult = f_read(&mySource,&res,1,&tmp); //check that file_read,read any thing or no if(tmp != 0 || fResult) { /* ..::**** problem is here ****::.. problem is here,that when i want to write res to opened file in sd card only write 4KB of file in it and then fputc return error!!! Surprisingly when change res in below line with '15'(an const int number) it write it correctly(!!!). note that res has valid value,i check it. */ if(fputc(res,myDest) == EOF) { copyRes = 0; break; } } else break; } //closing opened files for(res = 0;res < 3;res++) { if(f_close(&mySource) == FR_OK) break; else if(res == 2) copyRes = 0; } for(res = 0;res < 3;res++) { if(fclose(myDest) == 0) break; if(res == 3) { return 0; } } if(copyRes == 1) return 1; else return 0; }
now any one can help me to fix this problem,any one has any experience with keil flash file system????? Excuse me for long question,i did not know how make it shorter.
regards,alireza sd.
And what, exactly, was that?
What were you expecting?
What actually happened?
Why was that confusing?
What have you done to resolve the confusion?
as i explained in above,problem appear when i want write to sd/mmc card with keil flash file system(while reading process from it done well). look at below line :
in above res is one byte that was readed from opened file from usb flash disk,in above fputc work only for 4KB(4096) byte and in byte 4097 it return EOF. and that's what made me confused is that when in above function,in above line when i change res with '0x0F'(an const integer),it write correctly n(n is size of file that must be copy in byte) '0x0F' in file. why it work for for const integer and no for a variable?????
i got solved it, only in File_Config.c i change file system cache from 4kb to off.....
Doesn't sound like you solved it. More sounds like a work-around.
If turning off the cache fixes it then it's time to ask Keil.
