CMSIS Driver UART Revision: V1.02
file C:\Keil\ARM\Pack\Keil\STM32F4xx_DFP\1.0.8\RTE_Driver\UART_STM32F4xx
function UART_IRQHandler (UART_RESOURCES *ptr_uart)
static void UART_IRQHandler (UART_RESOURCES *ptr_uart) { uint32_t sr; volatile uint32_t val; sr = ptr_uart->uart->SR; ... // Overrun error if (sr & USART_SR_ORE) { if (ptr_uart->info->event_mask & (1 << ARM_UART_EVENT_RX_OVERRUN)) ptr_uart->info->cb_event(ARM_UART_EVENT_RX_OVERRUN); } ... // Read data register not empty if (sr & USART_SR_RXNE) { if (ptr_uart->uart->CR1 & USART_CR1_RXNEIE) { if ((ptr_uart->info->rx.idx_in != ptr_uart->info->rx.idx_out) || ((ptr_uart->info->rx.idx_in == ptr_uart->info->rx.idx_out) && (ptr_uart->info->rx.empty == true))) { ptr_uart->rx_buffer[ptr_uart->info->rx.idx_in] = ptr_uart->uart->DR; ptr_uart->info->rx.empty = false; ptr_uart->info->rx.idx_in = (ptr_uart->info->rx.idx_in + 1) & (ptr_uart->rx_buffer_size - 1); val = (ptr_uart->info->rx.idx_in - ptr_uart->info->rx.idx_out) & (ptr_uart->rx_buffer_size - 1); val = (ptr_uart->rx_buffer_size - 1) - val; if ((ptr_uart->hw_flow == true) && (ptr_uart->manual_rts_cts == false)) { if (ptr_uart->flow_ctrl_threshold == val) GPIO_PinWrite(ptr_uart->pin_rts.port, ptr_uart->pin_rts.num, 1); } if (val == ptr_uart->info->rx.threshold) { if (ptr_uart->info->event_mask & (1 << ARM_UART_EVENT_RX_THRESHOLD)) ptr_uart->info->cb_event(ARM_UART_EVENT_RX_THRESHOLD); } } else { ptr_uart->uart->CR1 &= ~USART_CR1_RXNEIE; } } } ... } } }
Sometimes there's a situation when ORE flag is set, but RXNE is cleared. In that case the program is stucked in this UART_IRQ_Handler. If you want to see this situation in the debugger, you should close USART Registers Debug window, otherwise the debugger will read DR register and thus ORE flag will be cleared.
