;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; #include<p16f877a.inc>
__config _XT_OSC & _WDT_OFF & _PWRTE_OFF & _BODEN_OFF & _WRT_OFF & _DEBUG_OFF
bsf STATUS,5
movlw b'00000110' ; SPBRG value acc to baud Rate=6 & baud rate-9600,FOSC-4MHz movwf SPBRG bcf TXSTA,BRGH ;speed low bcf TXSTA,SYNC ; Asynchro ;bcf TRISC,7 ;bcf TRISC,6
bcf STATUS,5 bsf RCSTA,SPEN ;Serial Port Enable
bsf STATUS,5 bsf TXSTA,TX9 ; 9 bit data enable bsf TXSTA,TXEN ;Transmision Enable
movlw b'00101001' ; 8 bit data 00101001
bcf STATUS,5 movwf TXREG
bsf STATUS,5 bsf TXSTA,TX9D ; 9th bit
delay decfsz 20h,1 goto delay
bcf TXSTA,TXEN
bcf STATUS,5
bcf RCSTA,SPEN
end
Above is my assembly code for sending a number '297' through Serial Port of an pic16f877A microcontroler but when i load this to proteus and check by virtual terminal.. i got a totally different symbol continuously øøøøøøøøøøøøøøøøøøøøøøøøøøøøøøøøøøøøøø....... what is the reason please help me friends
This is not a PIC forum, how does this relate to Keil?
Assume you don't have the clocks you expect, or the framing is otherwise messed up.
1. Watch the waveforms on the CRO. Check, whether you are getting proper waveforms (the output is high when no data is being transmitted). 2. Transmit "AA" to check the clock period of 1 bit which will help you to determine the baudrate from waveform. 3. If you are getting proper waveforms, then match the Baud Rate of PIC with the baud rate of the receiver (Terminal where you are observing the baudrate).
a string of 'U*' (capital U) will create a perfect square wave with a frequency of half the baudrate.
If 8 data bits, one stop and no parity.
Result would vary with changes in some combinations of those settings.
