Hi Friends, I'm Currently working on C51v6.02 developed by Keil, I'm facing a problem with the compiler when I compile a similar code like this
main() { char xdata *Data_Ptr = 0x0000; /* Pointer to the 0x000 location */ while(some loop) *Data_Ptr++; /* Points to the next data location on the RAM-- here 0x0001 */ }
.\FILENAME(LINENUMBER): warning C275: FILENAME: expression with possibly no effect
Proudly wasting time since 1981
Yaswanth, if you use:
main() { char xdata *Data_Ptr = 0x0000; /* Pointer to the 0x000 location */ while(some loop) Data_Ptr++; /* Points to the next data location on the RAM-- here 0x0001 */ }
char xdata *Data_Ptr; Data_Ptr = 0x0000;
"you get same result" NO you don't!
Data_Ptr++; // Advances the pointer to the next location *Data_Ptr++ // Increments the value of the data pointed-to by the pointer!
I'm afraid, that's not true. The two statements are equivalent. The ++ and * operators have same precedence but are evaluated right to left. - Mike
Oh yeah. Maybe that's the reason for the warning: the pointer has been incremented, and then dereferenced, but nothing has been done with the dereferenced value?
Vaclav, I guess we need to do it this way.
char xdata *Data_Ptr; Data_Ptr = (char *) 0x0000; /* I guess this is the way it must be done */
/* If done this way */ Data_Ptr = 0x0000; /* you are not type casting it then in that case the compiler should/will give a warning -- Haven't tried it though. */
Data_Ptr++; /* Will point to the next location */ *Data_Ptr++; /* But surely this will point to the next location */
*Data_Ptr++;
Andrew,
(*Data_Ptr)++;
Hmm... Not sure what "the correct way" means. But the rest of the world increments a pointer this way:
Data_Ptr++;
++Data_Ptr; or Data_Ptr += 1; or Data_Ptr = Data_Ptr + 1;
*Data_Ptr++; this expression is same as *(Data_Ptr++); or Data_Ptr += 1, *Data_Ptr;
Got you... Thanks Mike. -Yaswanth
Yaswanth, " I guess we need to do it this way. char xdata *Data_Ptr; Data_Ptr = (char *) 0x0000; /* I guess this is the way it must be done */ /* If done this way */ Data_Ptr = 0x0000; /* you are not type casting it then in that case the compiler should/will give a warning -- Haven't tried it though. */ " There isn't necessary to do casting because it is only initialized pointer to char in xdata memory at location 0. Compiler cannot be confused anyway I think. C51 Keil compiler don't generate warning in this case. Rest of your question: I agree with Mike's last and Andrew's second contribution. Vaclav
I don't think the warning message is about pointer incrementing, instead, it is telling you that you are not doing any assignment operations in that loop - "expression with possibly no effect ".
I don't think the warning message is about pointer incrementing, instead, it is telling you that you are not doing any assignment operations in that loop - "expression with possibly no effect ". That's exactly what it's telling you. Look folks, we need to learn ISO/ANSI C before we can start attacking the Keil compiler. If * didn't have precedence over ++ then how would the classic memcpy() example ever work? E.g.
while (count--) { *pDest++ = *pSrc++; }
int main(void) { int status; for (;;) status; /* legal but useless */ return 0; }
