Problem when using attribute strictly inline
I have a function in which I used. On debugging I can see count value as 1000 in watch.
static void func1(void)
    uint32_t cnt;
    cnt = 1000;                                   /*  Create a counter variable   */
    while(  (--cnt)  &&  ( SD_WHILE_TX_FIFO_EMPTY ) );      /*  Wait while not TX_FIFO Empty */
    if(cnt == 0)
        sd_card_error = 1;                                /* Error Write failed */
    SSP0_DATA_REG = value;                                   /* Write the value */
However if I use. On debugging, cnt value is always zero in watch. Even if it is at statement cnt = 1000;:
__attribute__( ( always_inline ) ) __STATIC_INLINE  void func1(void)
    uint32_t cnt;
    if(cnt == 0)
