I was reading on misra website that for assigning 0 to unsigned variable, 'u' must be suffixed.
For example:
uint8_t my_cnt = 0U;
1. Does that even on declaring array I should use this.Like
uint8_t my_arr[10U];
2. Also while using switch cases like:
void func(uint8_t no) { switch(no) { case 1U: break; case 2U: break; } }
If yes then what if variable passed to switch is of int8_t type. In above example if
int8_t no;
Rule 10.6 (required): A "U" suffix shall be applied to all constants of unsigned type.
WHERE!
Is that a question?
Taken from document "MISRA-C:2004 Guidelines for the use of the C language in critical systems"
Rule 10.6 (required): A “U” suffix shall be applied to all constants of unsigned type. The type of an integer constant is a potential source of confusion, because it is dependent on a complex combination of factors including: The magnitude of the constant The implemented sizes of the integer types The presence of any suffixes The number base in which the value is expressed (i.e. decimal, octal or hexadecimal).
and
Signedness of constants should be explicit. Consistent signedness is an important principle in constructing well formed expressions. If a constant is of an unsigned type, it is helpful to avoid ambiguity by applying a “U” suffix. When applied to larger values, the suffix may be redundant (in the sense that it does not influence the type of the constant); however its presence is a valuable contribution towards clarity.
I never liked the look of Misra anyway.
#define signed_number 0xFF #define unsigned_number 0xFFU int8_t var_s; uint8_t var_u; int main (void) { var_s = signed_number; var_s = unsigned_number; var_u = signed_number; var_u = unsigned_number; while (1); }
Now think.
where did you read this [expletive deleted]
You're not seriously trying to tell us that with all the experience you claim, you've never even heard of MISRA?
