Does anyone know wether the internal RAM contents of the STM32-microcontroller changes during a soft-reset respective a power on reset? It would be useful to know for sure that (for example) the RAM content will be reliable safe during a soft-reset and that the RAM will be erased by a power-on reset. Is anyone out there knowing something about the reset-behavior? Thank You very much in advance!
The SRAM is NOT erased at power up, it contains random/undefined content. The SRAM will retain across an NRST (external, or internal), so strategically placed values will remain. The Keil C startup code will clear/copy static regions defined by your code load, the startup code can be further modified to clear/set the rest/entire/portions of memory as required/desired.
There is a 4KB portion of NVRAM as I recall in the RTC/BKP domain which can be cleared by the TAMPER pin.
If you want to pass parameters across a reset, I would suggest building a structure in which to place them, with a signature, and a checksum, this way you can validate and manage it more cleanly.
It's easy to change the project settings and make the RAM a couple of kB smaller. Then the last kB of the RAM will not be cleared by the startup code.
This memory can then be accessed by a pointer - possibly to a suitable struct.
And as noted - keep a good checksum on this data to differentiate between garbage from a cold power-on (or a crashing/trashing run) and valid data from a previous run.
