Can you tell me the way to debug or simulate the application in keil written for ARM920T based Samsung S3C2440A. Any one Basic example like GPIO.
All the ARM tool manuals are here:
http://www.keil.com/support/man_arm.htm
You should start, as the name suggests, with the Primer:
http://www.keil.com/support/man/docs/gsac/
Again, work through the example programs in the uVision manual:
http://www.keil.com/support/man/docs/uv4/uv4_examples.htm
Books to help you:
http://www.keil.com/books/
Thanks for your reply.
I need a basic example for S3C2440A GIPO that can simulate in keil4 . what are target settings fro it. i have written one example which is working on Friendly ARM T35 board but its not simulating under keil4. In keil its giving error like , * error 65: access violation at 0x00000000 : no 'execute/read' permission,.
So give it some 'execute/read' permission!
Have you checked the examples provided by Keil?
Are you using a Dev Kit from Samsung? Have you checked for examples provided by Samsung? Or your Samsung distributor?
ok,
where to give these permissions . I know how to debug for LPC2148 as i am new to this S3C2440A i am getting this error.
www.keil.com/.../search.asp
Thank you for reply ,
i did some modifications to my memory map file but again in some memory range i am getting the error 65;
here i am placing my mp file. LR_ROM1 0x00000000 { ; load region ER_ROM1 0x00000000 0x30400000 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) } RW_RAM1 0x30040000 0x0040000 { ; RW data .ANY (+RW +ZI) } RW_IRAM1 0x40000000 0x00001000 { .ANY (+RW +ZI) } } also can you tell me how can i attach a zip file to this post.so that i will attach my project basic code.
Waiting for reply sir.
