Dear All, please provide header file for delay function
I mean I need constant delay even processor frequency changed
Ex;
delay_ms(500);
Currently I am using following delay function which is varying when change the system clock
void Delay(__IO uint32_t nCount) { while(nCount--) { } }
please also advice what is the deferment between flowing veritable types
__IO uint32_t uint32_t
Thanks in advnace
I recommend that you consider using a hardware based timer for relatively long delays such as 500ms.
Look at the definition for __IO (and the others in the group) and you are likely to quickly see your answer.
#define __IO volatile /*!< Defines 'read / write' permissions */
PS: in case i dont understand the data-types/typecasts or for that matter any unknown variable/function name, i press "F12" key or "F1" key on keyboard
By "F1" key i meant browsing Keil help files in help menu.
The "F1" key doesnt Help in Keil. :P
Hi Thanks for the advice
I need software delay
delay_ms(500); mean only for example
I need long delay
please advice
The advice?
Check the chapter about timers in the processor documentation.
Or look for sample code or application notes about how to use the processor timers.
It isn't needed to use interrupts with the timers - it's possible to poll too. The main thing is that the timers ticks their time without caring about what other things happens.
