USART
Hi I'm having issue getting the data send from the usart1; I initialised properly, but the problem is not the rightdata is display on my PC terminal; I'm using stm32f407VG
#include "stm32f4xx.h"
#include <stdio.h>
void init_GPIO(void){
        GPIO_InitTypeDef GPIO_InitStruct;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_15 | GPIO_Pin_14 | GPIO_Pin_13 | GPIO_Pin_12; // we want to configure all LED GPIO pins
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT;              // we want the pins to be an output
        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_2MHz;   // this sets the GPIO modules clock speed
        GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;     // this sets the pin type to push / pull (as opposed to open drain)
        GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;   // this sets the pullup / pulldown resistors to be inactive
        GPIO_Init(GPIOD, &GPIO_InitStruct);                         // this finally passes all the values to the GPIO_Init function which takes care of setting the corresponding bits.
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0;            // we want to configure PA0
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN;         // we want it to be an input
        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_2MHz;//this sets the GPIO modules clock speed
        GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_DOWN;   // this enables the pulldown resistor --> we want to detect a high level
        GPIO_Init(GPIOA, &GPIO_InitStruct);                   // this passes the configuration to the Init function which takes care of the low level stuff
void initUART (uint32_t baud){
 GPIO_InitTypeDef GPIO_InitStructureTx;
 GPIO_InitTypeDef GPIO_InitStructureRx;
 USART_InitTypeDef USART_InitStructure;
 // Enable Clocks //
        //USART_Cmd(USART1, DISABLE);
 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);  // Enable clocks
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
 GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_USART1);
 GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_USART1);
 GPIO_InitStructureTx.GPIO_Pin = GPIO_Pin_6;                // Configure TX pin
 GPIO_InitStructureTx.GPIO_Mode = GPIO_Mode_AF;              // Push-Pull
 GPIO_InitStructureTx.GPIO_OType = GPIO_OType_PP;              // Push-Pull
 GPIO_InitStructureTx.GPIO_Speed = GPIO_Speed_2MHz;;              // 2MHz
 GPIO_Init(GPIOB, &GPIO_InitStructureTx);                // Initialise
 GPIO_InitStructureRx.GPIO_Pin = GPIO_Pin_7;               // Configure RX pin
 GPIO_InitStructureRx.GPIO_Mode = GPIO_Mode_IN;             // Push-Pull
 GPIO_InitStructureRx.GPIO_Speed = GPIO_Speed_2MHz;              // 2MHz
 GPIO_Init(GPIOB, &GPIO_InitStructureRx);                // Initialise
 USART_InitStructure.USART_BaudRate = baud;                // Set USART1 Baud Rate
 USART_InitStructure.USART_WordLength = USART_WordLength_8b;            // Set USART1 Word Length
 USART_InitStructure.USART_StopBits = USART_StopBits_1;             // Configure USART1 Stop Bits
 USART_InitStructure.USART_Parity = USART_Parity_No;              // Configure USART1 Parity Bits
 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;       // Configure USART1 Flow Control
 USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;           // Set USART1 Operation Mode
 USART_Init(USART1, &USART_InitStructure);                // Configure UART
 USART_Cmd(USART1, ENABLE);                    // Enable UART
void USART_puts(USART_TypeDef* USARTx, volatile char *s){
        while(*s){
                // wait until data register is empty
                while( !(USARTx->SR & 0x00000040) );
                USART_SendData(USARTx, *s);
                *s++;
void Delay(__IO uint32_t nCount)
  while(nCount--) {
int main()
        uint32_t brrrr=650;
        //uint32_t brrrr=0;
        uint32_t baud=1600;
        //printf("4");
        init_GPIO();
        initUART (1600);
        //USART_Configuration();
        USART_puts(USART1, "Garlir");
        while(1)
                //GPIOD->BSRRL = 0xF000; // set PD12 thru PD15
                        //GPIOD->ODR=1<<13;
//              if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0))
                GPIO_SetBits(GPIOD, GPIO_Pin_13);
                //USART_puts(USART1, "Garlir");
                USART_SendData(USART1, 'P');
                Delay(38000);
                                GPIO_ResetBits(GPIOD, GPIO_Pin_13);
                //USART_puts(USART1, "Ga");
                USART_SendData(USART1, 'L');
                Delay(38000);
                //USART1->BRR=52.125;
                //baud=baud+300;
                //initUART (baud);
                brrrr=brrrr+1;
                USART1->BRR=brrrr;
                Delay(38000);
  • Hy do you start with the very non-standard baudrate of 1600?
    And why do you then increase the baudrate with 1 for every iteration of the loop?
    It seems to me like you have decided the "trial and error" method of developing programs. Alas, there are billions and billions of possible ways to introduce errors, so "trial and error" is a very slow approach.
    Better to do "right" and then compare what happens with what should happen and deduce where reality deviates from the plan.
  • Hi;
    Thanks for the reply; I'm increasing the baud rate successively as to see if I'll get any character that make sense; so I can know that maybe I'm wrong with my clocks configuration. But when the terminal start receiving and displaying characters, I never identify any of the character I sent (in the code) till cutoff.
    these are the character I get on the terminal; I google more information on the problem but can find any.
    ðððððððððððððððððððððððððððððððððððððððððððððððððððððððððððððððð
    ¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼¼<<¼¼<<<<<<<<<<<<<<<<<< <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<88<<88<<8888888888<<88888888888888888888888888 88888888888888888888888888888888888888888888888888xx88xxxxxxxxxxxxxxÎÎðÎÎÎðÎðÎðÎ ðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎ ðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðÎðððððððððððððððððððððððððððððððððððððððððððððððððððððððððð ððððððððððððððððððððððððððððððððððððððððððððððððàðððàðàðàààààààààààààààààààààààà àààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààà àààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààààà àààààààààààààààààààààààààààààààààààààààààààààààààààààààààÀÀààààààààÀÀÀÀÀÀÀÀÀÀÀÀÀ ÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀÀ
  • Don't you have access to an oscilloscope? It is way easier to verify the baudrate by just looking at the signal from your transmission.
  • John;
    You do not mention what device that you are attempting to use so I feel free to refer you to the "Hello World" example in the Keil ARM Examples. It it built on the LPC2100 series.
    It is very simple and it works.
    Bradford
  • Hi;
    Finally I got it working, I'm using smt32f407VG; I had to use a max232 chip between then MCU and the PC.
    And still using the successive baud increment approach, I changed my main function to:
    int main()
            char valuez[40]={0};
            uint32_t baud=1600;
            init_GPIO();
            initUART (baud);
            while(1)
                    Delay(380000);
                    Delay(380000);
                    sprintf(valuez, "%d\n", baud);
                    USART_puts(USART1,valuez);
                    baud=baud+100;
                    initUART (baud);
                    Delay(38000);
    And on my terminal, I have:
    ààààààøøààààààøøààààààððððððððððÀÀÀÀÀÀÀÀÀÀÀÀÀÀ ðÀðÀàààààààààààüüüüüþþÀÀþÀÀþÀÀþÀ0À0À0À0À0À0À0À0À0À0À8À8À8À8ààààààààààààààààààààààààààààææxææææ8öööö8öööö<òòòò<òò<òò<òò¼òò¼òò¼òò¼òò¼óó¼òòóóóó ÃßÃßÃàÃàÃãÃãÃÜÀÃÜÀÃÜÃÃÜÃÃÜÄÃÜÄÃÜÇÃÜÇÃÜØÃÜØÃÜÛÃÜÛÃÜÜÃÜÜÃÜßÃÜßÃÜðÃÜð@ÿ8ÿ8ÿÃ8ÿÃ@ÿ8ÿ@ÿ8ÿ@ÿ8ÿ@ÿ8ÿ@ÿ8ÿ@ÿ8ÿ@ÿ8ÿ@ÿ8ÿ'ÿ8ÿ'ÿ8ÿ@ÿ8ÿ@ÿ8ÿ'ÿÿ'ÿÿ'ÿÿ'ÿÿ'ÿÿ'ÿÿ'ÿÿ'ÿÿ'ÿÿ'ÿÿ'ÿÿ'ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ ÿÿPPL18L188200áPL18300 PL18400áPL18500 PL18600áPL18700 PL18800áPL18900 PL19000áPL19100 PL19200 PL19300 PL19400 PL19500áPL19600 PL19700 PL19800 PL19900 PL20000áPL20100áP̲°200áP¬2³0°Ð²°°°¬¬ ¬ ¤ ¤ ¤ ¬¨¤¨¤¨¤¨¤¨¤¨¤¨¤
    it's clear that at a baud of 19200, I get the exact data.
    Thanks good day!
