Hi all. I use ARM LPC2148 for my project and i use Keil uVision4.
µVision V4.60.0.0
Tool Version Numbers: Toolchain: MDK-Lite Version: 4.60.0.0 Toolchain Path: C:\Keil\ARM\ARMCC\bin\ C Compiler: Armcc.Exe Assembler: Armasm.Exe V5.02.0.28 I have a problem with interrupt handler irq. I write the following code in language c:
#include <lpc214x.h> void tc0(void)__irq; unsigned i = 0; void main(void) { PLL0CFG=0x24; //Multipler and divider setup PLL0CON=0x01; //Enable PLL PLL0FEED=0xAA; //Feed sequence PLL0FEED=0x55; while(!(PLL0STAT & 0x0400)) ; //is locked? PLL0CON=0x03; //Connect PLL after PLL is locked PLL0FEED=0xAA; //Feed sequence PLL0FEED=0x55; VPBDIV=0x01; VICIntSelect = 0x00; VICVectAddr0 = (unsigned long)tc0; VICVectCntl0 = 0x20 | 4; VICIntEnable = 0x10; T0MCR = 0x03; T0MR0 = 0x00003000; T0TCR = 0x01; while(1) { //loop } } void tc0(void)__irq { i = 1; T0IR = 0x01; VICVectAddr = 0x00; }
When timer match to MR0, run the interrupt service routine tc0. At the end of interrupt service routine tc0 i don't return from service routine to main program. Where am I doing wrong? Why my program doesn't return from service routine? Help me Please. Thanks.
I have solved the problem. Thanks.
Hi, Fabio Fabio... Congrats for solving the problem. Can you please tell me the cause of problem and how you managed to solve it? I am facing a similar problem. I am using LPC2148 for my project. I think it will help me.
Thank you in advance.
Hi Fabio,
Can you tell me what did you do to solve this problem, I am having a similar issue with the PLL interrupt routein.
Thanks..
