RE: USB virtual comm
Reply to a new post on the Read-Only thread,
http://www.keil.com/forum/21035/
Ramesh goud
> am working on IAR evalution board (LPC2148) for USB virtual com. The sample code from keil is not working in this board.
Did you really try it?
I believe the CDC example (Keil\ARM\Boards\Keil\MCB2140\RL\USB\Device\CDC\) works on the IAR board without any change.
Here is the schematics of both boards,
Keil MCB2140
http://www.keil.com/mcb2140/mcb2140-schematics.pdf
IAR LPC2148 Development board
old.iar.com/.../LPC2148-board-schematic.pdf
To run the CDC example,
- Both boards mount a 12MHz crystal
- MCU VBUS pin (P0.23) connects to VBUS pin of the USB connector over resistors.
- DB9 connector on UART1 (COM1 / RS232_1)
The difference is just USB_CONNECT (P0.31) pin. MCB2140 doesn't use USB_CONNECT, but IAR board requires it.
The example code enables USB_CONNECT function in USBD_Init(), usbd_LPC214x.c.
In these observations, I believe the Keil CDC example works on the IAR board as it is.
Tsuneo
  • Hello Tsuneo, i've enable the pin P0.31, now it's showing that unknown device with that code, i hope the enumeration process is not working properly,
    The example code that was given by the IAR systems is working fine, it's detecting the COM over there. And he had provided the host driver to work.
    Tel me some suggestion...
  • > The sample code from keil is not working in this board.
    Err.. We may be talking about different examples.
    What is the "sample code" are you working on?
    Show the exact link or folder location.
    Tsuneo
  • www.nxp.com/search
    Dear Tsuneo,
    here am sharing the link and it contains the source code for LPC2148 USB Virtual Com. Please go through this and let me know if it's suitsble for IAR board or not, if it's, then tel me what are the changes to be needed.
    Thank U...
  • Hello Tsuneo, the board is detecting the com port, and the driver file is not supporting which he had provided and it's showing two comports there.How...!
    pls let me know what's happening here
    Thanking U
  • hello Tsuneo, it's working fine now. thanks 4 ur supporting in working on virtual com port
  • So what was the problem? How did you resolve it?
  • Hello, first step as you told that the pin for voltage changed to pin 31.
    then by downloading this hex file, it's recognized the com in device manager of PC. He had given a setup file(driver for host), in that you must match PID&VID of your USB_DeviceDescriptor in usbdesc.c
    He had provided two virtual com ports, u can turn it into single virtual com by changing the value of /* bNumInterfaces */ (0x02) to 0x01.
    It's better to change the class /* bInterfaceClass, */ to USB_DEVICE_CLASS_COMMUNICATIONS
    then it's working fine now,
    in my case my USB detected COM46, COM1(UART0) can communicate each. i.e what ever am sending the data from UARTO, am retriving on COM46(USB Buffer)
    here I noticied that if you want reset the board, first you've disconnect usb com port. then only you have to reset the board, otherwise once again it's asking for the host driver..
    That's all from my end....
    HAPPY NEW YEAR.....:)
  • Dear Tsuneo, let me know how to overcome the last issue, i.e. plugging and unplugging of USB cable.
    What I mean to say that after resetting the board we need to disconnet the comport before only. if not it's asking once again the drivers to update. after updating the driver for effective functionality it's asking to restart the PC.
    pls let me know.....
  • Dear Tsuneo, pls respond to my question, that drivers installation of usb comport.
    The problem is that.
    The host detected the device and if drivers can be installed. If you open the hyper terminal to work on the same com port, with out disconnecting port if you reset the micro controller board, the host is asking one more time to install the drivers for the same comport, and after successful updates of drivers, it's asking to reboot the system for effective working of the com port.
    So, my requirement is that without disconnecting the comport on hyper terminal, if I reset the micro controller board, the host can recognize the device and it should not ask for driver update.
    kindly respond to this thread.
    Thanking you....
