The easyweb example updates the web browser with values from the ADC about every several seconds or so. Is there a way to speed up the updates by tweaking the code? I'm not sure what triggers the updates, if it is a timer interrupt or just a timing loop, something else. Can someone point me in the right direction to help me speed things up?
Since it's good to learn a bit more about the platform and processor I suggest the general solution to the problem.
Check in the processor datasheet/user manual what ADC registers that starts a conversion. Find the function that starts the conversion and check what calls it. That should quickly indicate if it is a super-loop or if the ADC conversions are related to an interrupt.
Thanks for the reply. I don't think that it is an issue with the ADC timing, but rather with the HTML page update and transfer to the PC. Whatever triggers the HTML page update and sends it to the PC only occurs once every several seconds. I'm looking thru the code but havent found it yet. I believe the ADc is performing conversions at a very high rate, so that's not the problem.
You mean this: http://www.keil.com/download/docs/295.asp ?
That's a server, so it doesn't update the browser at all!
The Browser is the client - so it requests the updates...
www.jmarshall.com/.../
Except that the server can inform the web browser to auto-reload the page after a specific time. And that can happen in a number of ways.
It can happen with javascript on the page, using a timer to control next reload.
It can happen with a meta-tag in the header of the html page, like:
<meta http-equiv="refresh" content="5" >
Thanks folks, that was it! The html page had the line <meta http-equiv="refresh" content="5">, which I assume means refresh every 5 sec. so I changed it to a 1 and it now updates every second. thanks, that's what I needed.
