I am develop an application that will store data into a SD. I am having problems with times of record using the FlashFS. After record some LOGs, recording new entries is very slow. I am using: LPC1768 @ CCLK = 100 MHz RL-ARM 4.1 4GB SDHC Class 10 SD Card
Below my function for record:
void Record_Event (unsigned char log_type, unsigned int id) { char f_name[30]; FILE *logs_file; sprintf(f_name,"%2.2d%2.2d%2.2d%2.2d%2.2d%2.2d.LOG",LPC_RTC->DOM,LPC_RTC->MONTH,LPC_RTC->YEAR,LPC_RTC->HOUR,LPC_RTC->MIN,LPC_RTC->SEC); logs_file = fopen (f_name, "wb"); /* open a file for writing */ if (logs_file == NULL) { return; } fputc (log_type, logs_file); fputc ((id) & 0xFF,logs_file); fputc ((id >> 8) & 0x00FF,logs_file); fclose (logs_file); /* close the output file */ }
The recording time for up to 60 files is less than 1 second, but when already exist more than 60 files in SD Card, the new recordings are slower. The times for new recordings are: up to 60 files = 1s or less 60-70 = 1,5s 70-100 = 3s 100-150 = 5s
does anyone know why? any help is welcome.
may I refer you to this
I had a similar problem
http://www.keil.com/forum/19536/
I got around the issue with a different approach to the problem.
I have not tried repeating the old method off logging data and continue to work with what I now use
