I had this problem with lpc1343 if I work with ULINK2 there is no any problem. If I try to update through USB mass storage bootloader, program is not working. I analyse the condition and I arrive to this.
Interrupt vector 7 (reserved in assembler file) is the check sum of first 0-6 interrupt vector. I didnt find this in bin and hex file so this made hex file and bin file not correct for bootloader.
I program a board and after I copy file firmware.bin (after a programming with ULINK2) and this file was correct and useful for programming of LPC1343.
Keil version is 4.23.
Any tips?
Regards
Grattoni Enore
ElfDwT utility is available, described on this uVision User's Guide.
Signature Creator for NXP Cortex-M Devices http://www.keil.com/support/man/docs/uv4/uv4_ut_elfdwt.htm
Tsuneo
Thanks for your answer. Fixed.
