Hello!
I'm trying to run HTTP-server on my LPC1788 board. lwip stack works fine. But when I try to run http-server under RL-ARM programm doesn't start at all. I included to my project follow files: EMAC_LPC177x_8x.c, Net_Config.c, TCP_CM3.lib, TCPD_CM3.lib (and corresponding headers Net_Config.h, EMAC_LPC177x_8x.h). Here my program:
include "LPC177x_8x.h" #include "debug_frmwrk.h" #include "RTL.h" int main (void) { SystemInit(); debug_frmwrk_init(); _DBG_("Started!"); init_TcpNet (); while (1) { main_TcpNet(); } }
I want just to try ping my board from my PC Ethernet. Do you mind to explain to me what is wrong?
Regards, Vasilij.
How is lwIP related to this? Either way, you forgot to call timer_tick() at the right frequency. See TCPNet documentation.
You're not mixed TCPNet and lwIP, are you (ho, I think you do) ?
I didn't mixed lwip and RL-ARM/ I just checked my hardware with it. debug_frmwrk_init() - it's just some uart routines for debugging. So should I call timer_tick() by timer? But why program don't start at all& I dont see "Started!" in uart (_DBG_("Started!"); send it). If I remove commands init_TcpNet () and main_TcpNet() it does.
You should follow the integration instruction as they appear on this very site. I cannot tell why your controller does not start. Having said that, lwIP is much faster than TCPNet, particularly when uploading (sending) data (on a LPC2478/LPC1788, 220+[KB/s] vs. 5[KB/s]), and it's free...
May be it will be easier to understand if you see my project: dl.dropbox.com/.../rlArmWeb.zip
Thank you for your help! Does there exist some samples project where TcpNet from Rl-arm are implenented?
Of course there are samples - in your own installation path of the Keil toolchain. See here:
..\Keil\ARM\Boards\Keil\MCB2470\RL\TCPnet
Is your tcp_callback set?
I don't exactly understand what you mean, sorry. Should I manualy create tcp_callback?
Yep, and need to open a socket too, look into the sample projects provided by keil.
U16 tcp_callback (U8 soc, U8 event, U8 *ptr, U16 usPar) { // look for project example about what to do on this function return (0); } int main (void) { SystemInit(); init_TcpNet (); tcp_soc = tcp_get_socket (TCP_TYPE_SERVER , 0, 120, tcp_callback); if (tcp_soc != 0) { // Start listening on TCP port 80. tcp_listen (tcp_soc, 80); } while (1) { main_TcpNet (); if(DATA_received == __TRUE ) { process_incoming(); DATA_received = __FALSE; } } }
Sorry, what I gave you relates to TCP server, I'm not sure if that is what you are looking for.
It's that what I need! Thank you a lot for your help!
It's still don't working. I noticed that in my board used LAN8720 and in and in EMAC_LPC177x_8x.c LAN8700 used. Does it compatible?
YES AND THEY HAVE DIFFERENT IDENTIFIER VALUES. YOU MUST EDIT THE FILE.
Vasilij,
Maybe you need to rebuild using the correct PHY constant defined...?
