Hello!
I'm trying to run HTTP-server on my LPC1788 board. lwip stack works fine. But when I try to run http-server under RL-ARM programm doesn't start at all. I included to my project follow files: EMAC_LPC177x_8x.c, Net_Config.c, TCP_CM3.lib, TCPD_CM3.lib (and corresponding headers Net_Config.h, EMAC_LPC177x_8x.h). Here my program:
include "LPC177x_8x.h" #include "debug_frmwrk.h" #include "RTL.h" int main (void) { SystemInit(); debug_frmwrk_init(); _DBG_("Started!"); init_TcpNet (); while (1) { main_TcpNet(); } }
I want just to try ping my board from my PC Ethernet. Do you mind to explain to me what is wrong?
Regards, Vasilij.
Tamir Michael,
Where is this constant located?
I don't use TCPNet anymore, but it should be in EMAC_LPC177x_8x.c:
#ifdef _DP83848_ #define PHY_DEF_ADR DP83848C_DEF_ADR #define PHY_ID DP83848C_ID #else #define PHY_DEF_ADR KSZ8001_DEF_ADR #define PHY_ID KSZ8001_ID #endif
Thank you very much, it works!!! Another one question, do you mind? I need to dynamically create web pages using data from SD card and send large amounts of data by HTTP. Haw can I manually create HTTP responses?
yep, look for example : Keil\ARM\Boards\Keil\MCB1700\EasyWEB
You need to read TCPNet's user manual. Normally this is achieved by callback functions the user implements.
I try to respond to all tcp massages that come to my board by tcp_send (soc, "OLOLO!", 6); (soc - soket that used). I some changed LEDSwitch sample:
U16 tcp_callback (U8 soc, U8 evt, U8 *ptr, U16 par) { /* This function is called by the TCP module on TCP event */ /* Check the 'Net_Config.h' for possible events. */ par = par; if (soc != socket_tcp) { return (0); } switch (evt) { case TCP_EVT_DATA: /* TCP data frame has arrived, data is located at *par1, */ /* data length is par2. Allocate buffer to send reply. */ // procrec(ptr); tcp_send (soc, "OLOLO!", 6); break; case TCP_EVT_CONREQ: /* Remote peer requested connect, accept it */ return (1); case TCP_EVT_CONNECT: tcp_send (soc, "OLOLO!", 6); /* The TCP socket is connected */ return (1); } return (0); }
But answer doesn't come (I'm using Putty). What is wrong?
If I remember well tcp_send cannot be used from inside the callback.
And before invoking the tcp_send you need to get the tcp buffer which is the only one that tcp_send likes so invoking directly tcp_send (soc, "OLOLO!", 6); !!!! WILL NOT WORK.
do something like this:
void send_data (void) { U32 unMax; U8 *ucSendbuf; U32 unIndex; if (tcp_check_send (tcp_soc)) { unMax = your_size; ucSendbuf = tcp_get_buf (unMax); // copy bytes to send buffer. for (unIndex = 0; unIndex < your_size; unIndex++) { ucSendbuf[unIndex] = your_data; } tcp_send (tcp_soc, ucSendbuf, your_size); } }
Finally I did it! Once again thanks a lot for your help! My code follow:
void send_data (U8 tcp_soc) { U32 unMax; U8 *ucSendbuf; U8 data[] = "HTTP/1.0 200 Ok\r\nContent-Type: text/html; charset=utf-8\r\nConnection: close\r\n\r\n<html><head>Hello!</head><body> <h1>Nothing to see here</h1></body></html>\n";// if (tcp_check_send (tcp_soc)) { unMax = tcp_max_dsize (sizeof(data)); ucSendbuf = tcp_get_buf (unMax); memcpy(ucSendbuf, data, sizeof(data)); tcp_send (tcp_soc, ucSendbuf, sizeof(data)); } } static void timer_poll () { /* System tick timer running in poll mode */ static U32 time; if (SysTick->CTRL & 0x10000) { time++; if (time == 10) { /* Timer tick every 100 ms */ time = 0; timer_tick (); } } } //Opened socket----- static U8 socket_tcp; U16 tcp_callback (U8 soc, U8 evt, U8 *ptr, U16 par) { par = par; if (soc != socket_tcp) { return (0); } switch (evt) { case TCP_EVT_DATA: flag = 1; return (1); case TCP_EVT_CONREQ: return (1); case TCP_EVT_CONNECT: return (1); case TCP_EVT_ACK: return (1); } return (0); } void webServerTsk (void *pvParameters) { init_TcpNet (); socket_tcp = tcp_get_socket (TCP_TYPE_SERVER, 0, 10, tcp_callback); if (socket_tcp != 0) tcp_listen (socket_tcp, 80);//PORT_NUM for(;;) { timer_poll (); main_TcpNet (); if(flag == 1) { //It works and sends data send_data (socket_tcp); //It doesn't work and doesn't send data send_data (socket_tcp); flag = 0; } portYIELD(); } }
But now I can't to send more than one TCP message. What I'm doing wrong?
Not sure, but maybe the main_TcpNet() need to be invoked after each send_data , I suspect only the latest version of what was set on on the tcp buffer is sent when main_TcpNet() is invoked
Well here my programm:
void webServerTsk (void *pvParameters) { init_TcpNet (); socket_tcp = tcp_get_socket (TCP_TYPE_SERVER, 0, 10, tcp_callback); if (socket_tcp != 0) tcp_listen (socket_tcp, 80);//PORT_NUM for(;;) { timer_poll (); main_TcpNet (); if(flag == 1) { send_data (socket_tcp); main_TcpNet (); send_data (socket_tcp); flag = 0; } portYIELD(); } }
It still doesn't work. Any idea?
You can't send second data until the first has been acknowledged, which you see with a callback.
Which I guess implies that main_TcpNet() need to be invoked many times before the second send_data can be used.
Quite possibly. But really, communication with TCPnet should be more event driven anyway. I think the call to main_TcpNet() is best done in a loop, the acknowledgement event setting a flag which is picked up and actioned in another part of that loop.
It works! I just added while(wait_ack == __TRUE) main_TcpNet () before second tcpSend. Thanks a lot!
Well I build http_upload, and all works fine. But for some strange reason there is to slow upload speed (only 5kB/s). All web pages are on SD card. Does somebody know what is wrong and what should I to check?
