I am using Flash file system for interfacing sd card using SPI. MCU is LPC2138. Every thing is working fine except for fcheck() which always returns 1. I am using the latest versions MDK4.54 and RL4.13. Below is the idea of problem:
int main () { FILE *myFile; char str[50]; Initialize(); if(finit("M0:") == 0) { UART0_sendstring("SD card Init ok\r\n"); sprintf(str, "Free Space = %d\r\n", ffree("M0:")); UART0_sendstring(str); sprintf(str, "Fanalyse = %d\r\n", fanalyse("M0:")); UART0_sendstring(str); if (fanalyse("M0:") > 50) { UART0_sendstring("Defragmenting the Sd card.\r\n"); fdefrag ("M0:"); } sprintf(str, "Fcheck = %d\r\n", fcheck("M0:")); UART0_sendstring(str); myFile = fopen("M0:\\Files\\welcome.txt","w"); if(myFile != NULL) { fputs("Hello My name is salman. What is your name?\r\nI am going to the airport.\r\nWould you like to come with me.", myFile); } fclose(myFile); } else UART0_sendstring("SD card Init Failed\r\n"); while(1);
OUTPUT: SD card Init ok Free Space = 126189568 Fanalyse = 0 Fcheck = 1
One more thing, Previously i was using MDK4.21 and RL4.13 and fcheck() was working fine. Upgrading the MDK seems to have caused the problem.
I am sorry i rechecked it now. Its not working fine even at older version. Same error there too.
This function works with EFS only. http://www.keil.com/support/man/docs/rlarm/rlarm_fcheck.htm http://www.keil.com/support/man/docs/rlarm/rlarm_fanalyse.htm
Does it mean Embedded Flash System.
Flash Drive or SPI flash Drive or Ram drive.
No Memory card drive. ?
Ok i got it. these functions can not be used with FAT file system.
