Sir, I am using 89c4051 to convert digital to analog. pin 1.0 and 1.1 are used, but I am confused how to us? please help me I don't know anything.
Did you surfed at Atmel site, looking for ADC examples using the 8051 Analog Comparator ?
" href= "http://www.atmel.com/Images/doc0524.pdf">www.atmel.com/.../doc0524.pdf www.atmel.com/.../CODE_0524.zip
Also an old document of Intel describes a Successive Approximation method wih an R/2R ladder and an external analog comparator. www.mcu4u.eu/.../MSC51-AR526(ADC_Successive_Approximation).pdf
These methods can give a 5-8bits of precision/resolution on the measurement signal. Also some signal conditioning may be neccessary at input.
Note the difference between ADC and DAC.
The OP doesn't seem to want to measure any analog signal, but wants to generate an analog signal. If the chip already has a DAC, or PWM, then it doesn't seem meaningful to look at ADC examples.
It is pretty sure that the OP is confused about the message posted.
The pins P1.0 and P1.1 of AT80C4051 are the Analog comparator inputs, this microcontroller does not have an internal ADC or DAC peripheral.
The R/C method described in the Atmel appnote gives an example of how to use about 5pins (including P1.0 and P1.1) to create a 5-8bits of ADC.
For the DAC implementation the SAR example from Intel describes how to build an R/2R ladder to create the DAC section (half of the SAR system).
Another option is to use an external DAC or ADC set up with bit-banged I2C on P1.0 and P1.1 (SDA/SCL)
Too many options with microcontrollers, even for this aged one.
I am using 89c4051 to convert digital to analog. pin 1.0 and 1.1 are used, but I am confused how to us? please help me I don't know anything. since you "don't know anything" why not choose a derivative with a DAC, there are many, instead of "this aged one".
Thank you sir. I have gone through all the details that you have posted. it helped me a lot. Now I came to know the working of 89c4051(comparator). The code which you have posted is in assembly. But I am working on C, could you help me please...
Ya you are right but. But my company has suggested me to use this one.
What is the final purpose of this circuit ? AT80C4051 for DAC or ADC ?
atmel 89c4051 for DAC
Are you going to use external devices for DAC like I2C PCF8591 (4channels 8bit ADC and 1 channel 8bit DAC)
or
the DAC circuit must be implemented on mcu AT89C4051 alone using an R/2R ladder ?
How many pins of the 15 provided are available for the DAC operation ?
DAC using 89c4051 alone using look up table. I am giving some input voltage say 4v as input to p1.1 mcu will compare with referecnce voltage and as soon as both the voltages become equal it will generate a flag... here in the program I need initiate start of conversion, how to write code in C for start conversion?
The reference voltage you talk about has to be provided by the microcontroller using some pins connected to an R/2R ladder or by an RC single slope or dual slop.
ladder like this upload.wikimedia.org/.../420px-R2r-ladder.png
each pin of the microcontroller sets a bit of the generated voltage ikalogic.cluster006.ovh.net/.../r2r-.jpg
The output of this the ladder must be connected to P1.0 (since the unknown input voltage is connected to to P1.1)
The ladder method requires some more pins of the microcontroller but can give good precision and resolution if this occupies 7-10pins.
The RC ADC method mentionted previously is charging(or discharging) a capacitor up to a level where the Analog Comparator gives a signal of the two compared voltages. www.atmel.com/.../doc0524.pdf
The RC method uses only 5 pins and have a medium accuracy, but is easy to build.
Both methods are about comparing an unknown voltage with a reference voltage and when the comparator gives the signal changes state the the unkown voltage is equal with the known voltage.
So the algorithm is a continous loop where the ladder or the RC system is updated with new values and wait until the comparator signals the state change.
The analog comparator has it own interrupt system for Enable, Priority, Flag, Vector.
"The analog comparator is always disabled during Idle or Power-down modes" "The comparator operation is such that the output is a logical “1” when the positive input AIN0 (P1.0]) is greater than the negative input AIN1 (P1.1). Otherwise the output is a zero. Setting the CEN bit in ACSR enables the comparator." www.atmel.com/.../doc3390.pdf
ya, your are correct, mcu will provide the reference voltage. while designing we need to set the reference voltage. But the problem here is how to start the comparison? do i need to write software coding for that or it keeps on comparing? As you said we need to enable the comparator i.e set bit CEN of ACSR. but 89c4051 does not have ACSR. what to do? please help me bit in coding... help me in coding how to start comparing? using interrupt or enabling comparator? or any other metods? if you have code please post it
For the AT89C4051 microcontroller the output of analog comparator is defined as: "P3.6 is hard-wired as an input to the output of the on-chip comparator and is not accessible as a general-purpose I/O pin." www.atmel.com/.../doc1001.pdf
The "next" model of AT89S4051 has the ACSR SFR (and PWM also) www.atmel.com/.../doc3390.pdf
Thank you sir, you helped me a lot.
Sir, mcu 89v51rd2 is not communicating serially. rs232 cable is working. mcu was communicating 4 days before, but now it is not communicating.. I have lost 2 mcu. what would be the problem?
