External interrups stops Match Interrupts
Hello experts,
With LPC2138 I am developing a control system hardware and software for a packaging machine industry. I am unable to understand the below described behavior.
I am using Proteus to simulate my code.
I have connected a 50Hz square wave signal at EINT2 and digital switch at EINT1 as Interrupts.
Three LEDs and scopes at P0.0, 1 and 2 along with oscilloscopes to analyze.
I have noticed three behaviors which I am unable to understand.
Please help me.
P0.0 is at logic 1 just after around 0.5ms. Then it is toggled as per the digital input.
I think __irq void eint1_srv is executed once at first without any interrupt.
P0.1 toggles correctly from input square wave first edge and works without any issue.
When I give interrupts at digital switch, with second interrupt the frequency of P0.2 increases or at third interrupt P0.2 stays at logic 0 or 1 permanently. I think capture interrupt __irq void T0MR0_ISR is not called further.
Please help me.
__irq void eint1_srv (void);
__irq void eint2_srv (void);
__irq void T0MR0_ISR (void);
unsigned long op1=0, op2=0, vib=0;
unsigned long temp=0;
#include <LPC21xx.H>
int main(void)
IODIR0 = 0x0000FFFF;
/*Initialization of EINT1 and EINT2*/
EXTMODE = 0x0F;
EXTPOLAR = 0x0F;
PINSEL0 = 0xA0000000;
VICVectAddr1 = (unsigned long) eint1_srv;
VICVectCntl1 = 0x20 | 15;
VICVectAddr2 = (unsigned long) eint2_srv;
VICVectCntl2 = 0x20 | 16;
VICIntEnable = (1<<15) | (1<<16);
/*Initialization of Match OP*/
T0MR0 = 75000L;
T0PR = 0x00000000;
T0MCR = 0x00000003;
VICVectAddr4 = (unsigned long)T0MR0_ISR;
VICVectCntl4 = 0x20|4;
VICIntEnable = 1<<4;
T0TCR = 0x00000001;
while(1)
++temp;
if (temp>1000) temp=0; }
if(op1==0)
op1=1;
IO0SET = 1<<0;
else
op1=0;
IO0CLR = 1<<0;
T0MR0 = 30000L;
EXTINT = 1<<1; // Clear EINT1 interrupt flag
VICVectAddr = 0; // Acknowledge Interrupt
if(op2==0)
op2=1;
IO0SET = 1<<1;
// T0MR0 = 15000L;
else
op2=0;
IO0CLR = 1<<1;
// T0MR0 = 50000L;
EXTINT = 1<<2; // Clear EINT2 interrupt flag
if (vib==0)
vib = 1;
IO0SET = 1<<2;
else
vib = 0;
IO0CLR = 1<<2;
T0IR = 1<<0;
VICVectAddr = 0;
