REG: LPC 2129 SPI
Good Morning.
Have tried to communicate with 25LC160 eeprom through LPC2124 USING keil u 4 and proteus
In that case , in transmission section SPI terminal gives 00 when am transmit 00 but in that case of 01 terminal gives ? in the position of 0 th bit .
In keil simulation SOSPDR is not accepting the data which am giving
SCK - 1Mhz
#include <LPC21xx.H>
#define bit(x)  (1<<x)
#define SCK0    8
#define MISO0   10
#define MOSI0   12
void io_config(void);
void spi_config(void);
void spi_tx(unsigned char);
void delay(unsigned int);
int main(void)
        io_config();
        spi_config();
        IOSET0 |= 1<<1;
        //spi_tx(0x00);
        //spi_tx(0x00);
        spi_tx(0x01);
        while(1)
//              IOSET0 |= 1<<1;
//              delay(1000);
//              IOCLR0 |= 1<<1;
//              delay(1000);
        IODIR0 |= 1<<1;
         VPBDIV = 0X02;
         PINSEL0 = 0 | bit(SCK0) | bit(MISO0) | bit(MOSI0);
         S0SPCR  = 0X20;
         S0SPCCR = 0X1E;
void delay(unsigned int dly_val)
         unsigned int i;
         for(i=0;i<dly_val;i+=1)
void spi_tx(unsigned char data)
         unsigned char dummy;
         unsigned char dummy1;
         IOCLR0 |= 1<<1;
         dummy = S0SPDR;
        // delay(2000);
         dummy1 = S0SPSR;
        // delay(2000);
         S0SPDR =data;
        // delay(2000);                         // Intialize transfer
        while(!(S0SPSR&(0x80)));            // Wait for trasfer to finish
        // delay(2000);
        dummy = S0SPDR;
        // delay(2000);
         IOSET0 |= 1<<1;
         delay(2000);
Give some idea guys
