hi all
I am using LPC2368 processor, i written following code to impliment the RS232 in UART0,but i am getting above message while debugging. please let me know whats wrong here...
#include "LPC23xx.h" /* LPC23xx definitions */ #include "uart.h"
void UART1Handler (void)__irq ; void UARTSend(BYTE *BufferPtr, DWORD Length ); void Uart_transmit (char *data); void UARTInit(unsigned long baudrate);
void UART1Handler (void)__irq { unsigned char IIRValue, LSRValue;
unsigned char Dummy = Dummy;
IIRValue = U0IIR;
IIRValue >>= 1;
IIRValue &= 0x07;
if ( IIRValue == IIR_RLS )
LSRValue =U0LSR;
if ( LSRValue & (LSR_OE|LSR_PE|LSR_FE|LSR_RXFE|LSR_BI) )
UART1Status = LSRValue;
Dummy = U0RBR;
VICVectAddr = 0;
return;
if ( LSRValue & LSR_RDR )
UART1Buffer[UART1Count] = U0RBR;
UART1Count++;
if ( UART1Count == BUFSIZE )
UART1Count = 0;
else if ( IIRValue == IIR_RDA )
else if ( IIRValue == IIR_CTI )
UART1Status |= 0x100;
else if ( IIRValue == IIR_THRE )
LSRValue = U0LSR;
if ( LSRValue & LSR_THRE )
UART0TxEmpty = 1;
else
UART0TxEmpty = 0;
void UARTSend(BYTE *BufferPtr, DWORD Length)
while ( Length != 0 )
while ( !(UART0TxEmpty & 0x01) );
U0THR = *BufferPtr;
BufferPtr++;
Length--;
while (*data)
U0THR=*data++;
U0THR=0x0A;
unsigned long Fdiv;
PINSEL0=0X00000050;
U0LCR = 0x83;
Fdiv = (Fpclk/16)/baudrate ;
U0DLM = Fdiv / 256;
U0DLL = Fdiv % 256;
U0LCR = 0x03;
U0FCR = 0x07;
VICIntEnClr = 1 << 6;
VICVectAddr6 = (unsigned long )UART1Handler;
VICVectCntl6 = 0x01;
VICIntEnable |= 1 << 6;
U0IER = IER_RBR | IER_THRE | IER_RLS; }
int main (void)
PINSEL10 = 0;
PINSEL4=0X00000000;
FIO2DIR |= 0x000000FF;
FIO2PIN |= 0x00000001;
UARTInit(9600);
Uart_transmit("abcdef");
while (1)
if ( UART1Count == 0 )
{ U0IER = IER_THRE | IER_RLS;
UARTSend((BYTE *)UART1Buffer, UART1Count );
U0IER = IER_THRE | IER_RLS | IER_RBR;
return 0; }
Please learn to read the posting tips and use the PRE tags when posting source.
You need to look at the code being generated and placed at that address, then perhaps you'll have a better idea why. Put a breakpoint in the debugger, or review a listing file, or the map file. Perhaps it's in the startup.s file. It's real hard to know from looking at the source provided.
Is that the address of the VIC?
