Hi All,
Do anyone has idea how i can assign the bit allocation to certain memory address?
For now i could only use the _at_ to assign the character.
I am actually try to emulate the following assembly code. The SET_KEY is actually 2C.0, MINUS is 2C.1 and the PLUS is 2C.2. Anybody knows how i can do it in C using KEIL?
KEYS_NEW EQU 02CH ; TEST EQU 062H ; TEST key current status MINUS EQU 063H ; MINUS key current status PLUS EQU 064H ; PLUS key current status
So what's the problem with that?
The specific purpose of the _at_ keyword extension is precisely to locate a variable at the given address!
You use _at_ to assign a variable in BDATA, and then define the specific bits within that variable...
http://www.keil.com/support/man/docs/c51/c51_le_bitaddrobj.htm
http://www.keil.com/support/man/docs/c51/c51_le_bdata.htm
Thanks Andrew,
I got it works.
