Hi all,
I am trying to run the Blinky example for the STM32 Discovery board. The path is typically:
C:\Keil\ARM\Boards\ST\STM32-Discovery\Blinky\Blinky.uvproj
When I run the example project on the board I can debug and single step through the program. However, when I try to run the project on the simulator I get the following:
*** Error: invalid option '-REMAP'
*** error 65: access violation at 0x0000000C : no 'read' permission
I probably have a setting messed up but cannot track it down.
Thanks,
Trevor.
Note that there are (at least) 4 different "STM32 Discovery" boards.
Which one, exactly, are you using - and are you sure you are using the correct project?
The documentation I have says: STM32F100RB microcontroller, 128 KB Flash, 8 KB RAM in 64-pin LQFP
The Device selected when I load the Blinky project is STM32F100RB so I think I have it right. Also, I can flash the board with the example project and debug (step..).
The problem is when I go to the Debug Tab (Project->Options) and select simulator I receive that error I stated. I just want to run the sim and do some non-peripheral debugging. I am sure I have something simple messed up since I am not experienced with these tools, but cannot find it.
Thx,
Trevor
Hello Trevor, the device you use is not fully simulated as you can see in the DeviceDatabase: http://www.keil.com/dd/chip/5086.htm
On a Cortex-M3 device with ETM (Embedded Trace Macrocell) simulation becomes more or less unnecessary. ULINKpro (http://www.keil.com/ulinkpro) can provide almost all advanced analysis features simulation offers from a hardware target.
Regards, Matthias
