Curiosity Killed The Geek
Question:
Out of purely a curiosity thing I formatted an SD Card using Windows XP and a card reader. I then looked at sector 0 and found the FAT32 information as per MS.
I then ran a Keil example program on my ST eval board and formatted the SD Card using the /fat32 switch.
Whn I looked at sector 0 I could not find the FAT32 MBR.
BUT, At offset 0x1BE of sector 0 I found some non-zero bytes.
00 01 01 00 0B FE FF FF 08 01 00 00 FF 22 B7 03
After further research I found this info:
The next 64 bytes contain the partition table. Information on each partition begins at the following offsets:
            Partition 1: 0x1BE (446)
            Partition 2: 0x1CE (462)
            Partition 3: 0x1DE (478)
            Partition 4: 0x1EE (494)
Each partition table entry contains the following information (offsets are for partition 1):
Offset               Length Contents
0x1BE              1 byte               Boot Indicator: 0x00=no boot, 0x80=boot
0x1BF              1 byte               Starting Head
0x1C0              6 bits                Starting sector. Bits 0-5 are used
0x1C1              10 bits              Starting Cylinder: Bits 6-7 of 0x1C0 are used with this
                                                  byte. Max value is 1023.
0x1C2              1 byte               System ID
                        ID        Partition type
                        0x1      FAT12 primary partition or logical drive (fewer
                                    than 32,680 sectors in the volume)
                        0x4      FAT16 partition or logical drive (32,680–65,535 sectors or
                                    16 MB–33 MB)
                        0x5      Extended partition
                        0x6      BIGDOS FAT16 partition or logical drive (33 MB–      4 GB)
                        0x7      Installable File System (NTFS partition or logical drive)
                        0xB      FAT32 partition or logical drive
                        0xC      FAT32 partition or logical drive using BIOS INT 13h extensions
                        0xE      BIGDOS FAT16 partition or logical drive using BIOS INT 13h
                                    extensions
                        0xF      Extended partition using BIOS INT 13h extensions
                        0x12    EISA partition or OEM partition
                        0x42    Dynamic volume
                        0x84    Power management hibernation partition
                        0x86    Multidisk FAT16 volume created by using Windows NT 4.0
                        0x87    Multidisk NTFS volume created by using Windows NT 4.0
                        0xA0    Laptop hibernation partition
                        0xDE   Dell OEM partition
                        0xFE    IBM OEM partition
                        0xEE    GPT partition
                        0xEF    EFI System partition on an MBR disk
0x1C3              1 byte               Ending head
0x1C4              6 bits                Ending sector. Bits 0-5 are used
0x1C5              10 bits              Ending cylinder. Bits 6-7 of 0x1C4 are used with this byte.
                                                 Max value is 1023.
0x1C6              4 bytes             Relative sectors. The offset from the beginning of the disk
                                                 to the beginning of the volume, counting by sectors.
0x1CA             4 bytes             Total sectors. The total number of sectors in the volume.
So, I determined that at offset 0x108 (or 135,168 bytes) into memory that the FAT32 table should reside there. After reading a memory block starting at 135,168 I did find the FAT32.
Question then: Why does Keil library skip 135,168 bytes before writing the FAT table?
Also, as a side note, if the Card is formatted by Keil library and then tried to be reformatted by Windows it fails. If I blow away sector 0, then Windows can reformat the disk? If Windows formats the disk, Keil code can operate with it fine.
Although most of this is irrelevant to the casual user if you just use the library out-of-the- box, I usually do not 'accept on faith' that binaries will properly function.
Thus, the curiosity.....
