Hallo guys, I have great difficulties linking my code. The compiler somehow does not know where to find my cypress registers declared in this header "fx2regs.h". I'm trying to build a firmware for my cypress usb on my FPGA. I keep getting 124 Errors of type: ***WARNING L1/L2: UNRESOLVED EXTERNAL SYMBOL SYMBOL: USBCS etc. MODULE: .fw\obj (FW) Example code: ---------------------------------------------------------------------------------------- #pragma NOIV // Do not generate interrupt vectors ////////////////////////////////////////////////////////////////////////////////// // $Source: /cvs/dvbt2/cypress_usb/usb_tx.c,v $ // $Revision: 1.3 $ // $Date: 2009/01/27 13:21:41 $ // $Author: Kocks $ // DVB-T2 // Firmware for Cypress USB controller ////////////////////////////////////////////////////////////////////////////////// #include "fx2.h" #include "fx2regs.h" #include "fx2sdly.h" // SYNCDELAY macro
extern BOOL GotSUD; // Received setup data flag extern BOOL Sleep; extern BOOL Rwuen; extern BOOL Selfpwr;
BYTE Configuration; // Current configuration BYTE AlternateSetting; // Alternate settings
#define VR_NAKALL_ON 0xD0 #define VR_NAKALL_OFF 0xD1
//----------------------------------------------------------------------------- // Task Dispatcher hooks // The following hooks are called by the task dispatcher. //-----------------------------------------------------------------------------
#define USE_EXTERNAL_CLOCK 0
void TD_Init(void) // Called once at startup {
// Registers which require a synchronization delay, see section 15.14 // FIFORESET FIFOPINPOLAR // INPKTEND OUTPKTEND // EPxBCH:L REVCTL // GPIFTCB3 GPIFTCB2 // GPIFTCB1 GPIFTCB0 // EPxFIFOPFH:L EPxAUTOINLENH:L // EPxFIFOCFG EPxGPIFFLGSEL // PINFLAGSxx EPxFIFOIRQ // EPxFIFOIE GPIFIRQ // GPIFIE GPIFADRH:L // UDMACRCH:L EPxGPIFTRIG // GPIFTRIG
// Note: The pre-REVE EPxGPIFTCH/L register are affected, as well... // ...these have been replaced by GPIFTC[B3:B0] registers
// set the CPU clock to 48MHz CPUCS = ((CPUCS & ~bmCLKSPD) | bmCLKSPD1) ;
// set the slave FIFO interface to 48MHz // IFCLK pin is driven by the internal 48Mhz clock wth inverted polarity #if USE_EXTERNAL_CLOCK == 1 IFCONFIG = 0x73; // 01110011 #else IFCONFIG = 0xF3; // 11110011 #endif // bit 7: IFCLKSRC == 0x01: internal clock is used // bit 6: 3048MHZ == 0x01: 48 MHz clock // bit 5: IFCLKOE == 0x01: IFCLK pin driven // bit 4: IFCLKPOL == 0x01: output clock is inverted // bit 3: ASYNC == 0x00: slave FIFOs operate synchronously // bit 2: GSTATE == 0x00: // bit 1-0: IFCFG[1:0] == 0x03: interface mode: slave FIFO interface
SYNCDELAY; REVCTL = 0x03; // see TRM p.131 SYNCDELAY;
// default: all endpoints have their VALID bit set // default: TYPE1 = 1 and TYPE0 = 0 --> BULK // default: EP2 and EP4 DIR bits are 0 (OUT direction) // default: EP6 and EP8 DIR bits are 1 (IN direction) // default: EP2, EP4, EP6, and EP8 are double buffered
// configuration of endpoints // endpoint 1 EP1OUTCFG = 0xA0; EP1INCFG = 0xA0; SYNCDELAY; // see TRM section 15.14
// endpoint 2 EP2CFG = 0xEA; // bit 7: VALID == 0x01: endpoint valid // bit 6: DIR == 0x01: IN endpoint // bit 5-4: TYPE == 0x02: bulk endpoint // bit 3: SIZE == 0x01: size = 1024 // bit 1-0: BUF == 0x02: double buffering SYNCDELAY;
// endpoint 4 (disabled) EP4CFG = 0x62; SYNCDELAY;
// endpoint 6 EP6CFG = 0xEA; SYNCDELAY;
// endpoint 8 (disabled) EP8CFG = 0x62; SYNCDELAY;
// reset all FIFOs FIFORESET = 0x80; SYNCDELAY;
FIFORESET = 0x02; SYNCDELAY;
FIFORESET = 0x04; SYNCDELAY;
FIFORESET = 0x06; SYNCDELAY;
FIFORESET = 0x08; SYNCDELAY;
FIFORESET = 0x00; SYNCDELAY;
// configure FIFOs for AUTOIN-mode EP2FIFOCFG = 0x4D; // bit 6: INFM1 == 0x01: assert full flag one sample earlier than when the full condition occurs // bit 5: OEP1 == 0x00 // bit 4: AUTOOUT == 0x00 // bit 3: AUTOIN == 0x01: incoming data is automatically packetized and transmitted, without CPU intervention // bit 2: ZEROLENIN == 0x01: enable zero length IN packets // bit 0: WORDWIDE == 0x01: 16 bit word width SYNCDELAY;
EP6FIFOCFG = 0x4D; SYNCDELAY;
// set block length to 1024 (only permitted for EP2 and EP6) EP2AUTOINLENH = 0x04; SYNCDELAY; EP2AUTOINLENL = 0x00; SYNCDELAY;
EP6AUTOINLENH = 0x04; SYNCDELAY; EP6AUTOINLENL = 0x00; SYNCDELAY;
// Rwuen = TRUE; // Enable remote-wakeup }
void TD_Poll(void) // Called repeatedly while the device is idle { // this function is empty since the USB controller is operating in FIFO slave mode }
BOOL TD_Suspend(void) // Called before the device goes into suspend mode { return(TRUE); }
BOOL TD_Resume(void) // Called after the device resumes { return(TRUE); }
//----------------------------------------------------------------------------- // Device Request hooks // The following hooks are called by the end point 0 device request parser. //-----------------------------------------------------------------------------
BOOL DR_GetDescriptor(void) { return(TRUE); }
BOOL DR_SetConfiguration(void) // Called when a Set Configuration command is received { // inserted recently if( EZUSB_HIGHSPEED( ) ) { // ...FX2 in high speed mode EP2AUTOINLENH = 0x04; SYNCDELAY; EP6AUTOINLENH = 0x04; // set core AUTO commit len = 512 bytes SYNCDELAY; EP2AUTOINLENL = 0x00; SYNCDELAY; EP6AUTOINLENL = 0x00; } else { // ...FX2 in full speed mode EP2AUTOINLENH = 0x00; SYNCDELAY; EP6AUTOINLENH = 0x00; // set core AUTO commit len = 64 bytes SYNCDELAY; EP2AUTOINLENL = 0x40; SYNCDELAY; EP6AUTOINLENL = 0x40; } Configuration = SETUPDAT[2]; return(TRUE); // Handled by user code }
BOOL DR_GetConfiguration(void) // Called when a Get Configuration command is received { EP0BUF[0] = Configuration; EP0BCH = 0; EP0BCL = 1; return(TRUE); // Handled by user code }
BOOL DR_SetInterface(void) // Called when a Set Interface command is received { AlternateSetting = SETUPDAT[2]; return(TRUE); // Handled by user code }
BOOL DR_GetInterface(void) // Called when a Set Interface command is received { EP0BUF[0] = AlternateSetting; EP0BCH = 0; EP0BCL = 1; return(TRUE); // Handled by user code }
BOOL DR_GetStatus(void) { return(TRUE); }
BOOL DR_ClearFeature(void) { return(TRUE); }
BOOL DR_SetFeature(void) { return(TRUE); }
BOOL DR_VendorCmnd(void) { return(FALSE); } ---------------------------------------------------------------------------------- Can somebody point me to the right direction.
http://www.keil.com/support/man/docs/lx51/lx51_l1.htm
http://www.keil.com/support/man/docs/lx51/lx51_l2.htm
You also need to pay attention to the clearly-stated instructions for posting source code - see this picture: www.danlhenry.com/.../keil_code.png
