SPI not transmitting on NXP LPC4357 (MCB4357)
Hi guys,
I've just attempted to hash together some basic SPI test code, however, the module doesn't appear to be shifting data out to transmit. The Transmit Complete flag isn't triggering and my Logic Analyser isn't picking anything up on the relevant pins.
My code is as follows:
#define  CMSIS_BITPOSITIONS 1
#include <LPC43xx.h>
int main( void )
        // Update the System Core Clock
        SystemCoreClockUpdate();
        // Configure pins for SPI
        LPC_SCU->SFSP3_6 = 1; // MISO
        LPC_SCU->SFSP3_7 = 1; // MOSI
        LPC_SCU->SFSP3_3 = 1; // SCK
        LPC_SCU->SFSP3_8 = 1; // SSEL
        // Configure the SPI Master Clock (PCLK_SPI / SPCCR)
        LPC_SPI->CCR = 16;
        // Configure the SPI Module for Master Mode
        LPC_SPI->CR |= SPI_CR_MSTR_Msk;
        while( 1 )
                LPC_SPI->DR = 0xA1;
                while( !(LPC_SPI->SR & SPI_SR_SPIF_Msk) );
The unit appears to be powered, as I'm able to to set values in LPC_SPI->CR and LPC_SPI->CCR, however there's no evidence that data being inserted into LPC_SPI->DR is being shifted out.
I'm new to the 4357 and so perhaps I'm missing a step in clock setup? It's my understanding that SPI is enabled by default with a default base clock from the IRC.
Greatly appreciate any help,
Many thanks
  • You should probably check your assumption for BASE_SPI_CLK, either by confirming the current value, or setting it explicitly.
  • I've just taken a look, all SPI clocks/gates appear to be active.
  • I've extended the code to the following but still no luck:
            // Enable SPI and Peripheral Clocks
            LPC_CGU->BASE_SPI_CLK = ((0x00UL << CGU_BASE_SPIFI_CLK_PD_Pos) & CGU_BASE_SPIFI_CLK_PD_Msk) |                                                              // Enable Output Stage
        ((0x00UL << CGU_BASE_SPIFI_CLK_AUTOBLOCK_Pos) & CGU_BASE_SPIFI_CLK_AUTOBLOCK_Msk) | // Disable autoblocking
        ((0x01UL << CGU_BASE_SPIFI_CLK_CLK_SEL_Pos) & CGU_BASE_SPIFI_CLK_CLK_SEL_Msk);                        // Clock Select (IRC)
            LPC_CGU->BASE_PERIPH_CLK = ((0x00UL << CGU_BASE_PERIPH_CLK_PD_Pos) & CGU_BASE_PERIPH_CLK_PD_Msk) |                                                  // Enable Output Stage
        ((0x00UL << CGU_BASE_PERIPH_CLK_AUTOBLOCK_Pos) & CGU_BASE_PERIPH_CLK_AUTOBLOCK_Msk) | // Disable autoblocking
        ((0x01UL << CGU_BASE_PERIPH_CLK_CLK_SEL_Pos) & CGU_BASE_PERIPH_CLK_CLK_SEL_Msk);                      // Clock Select (IRC)
            LPC_CCU1->CLK_PERIPH_BUS_CFG = ((0x01UL << CCU1_CLK_PERIPH_BUS_CFG_RUN_Pos) & CCU1_CLK_PERIPH_BUS_CFG_RUN_Msk) |                   // Enable Clock Run
        ((0x00UL << CCU1_CLK_PERIPH_BUS_CFG_AUTO_Pos) & CCU1_CLK_PERIPH_BUS_CFG_AUTO_Msk) |          // Disable autoblocking
        ((0x00UL << CCU1_CLK_PERIPH_BUS_CFG_WAKEUP_Pos) & CCU1_CLK_PERIPH_BUS_CFG_WAKEUP_Msk); // Disable Wakeup
            LPC_CCU1->CLK_PERIPH_CORE_CFG = ((0x01UL << CCU1_CLK_PERIPH_CORE_CFG_RUN_Pos) & CCU1_CLK_PERIPH_CORE_CFG_RUN_Msk) |                         // Enable Clock Run
        ((0x00UL << CCU1_CLK_PERIPH_CORE_CFG_AUTO_Pos) & CCU1_CLK_PERIPH_CORE_CFG_AUTO_Msk) |        // Disable autoblocking
        ((0x00UL << CCU1_CLK_PERIPH_CORE_CFG_WAKEUP_Pos) & CCU1_CLK_PERIPH_CORE_CFG_WAKEUP_Msk); // Disable Wakeup
            LPC_CCU1->CLK_SPI_CFG = ((0x01UL << CCU1_CLK_SPI_STAT_RUN_Pos) & CCU1_CLK_SPI_STAT_RUN_Msk) |                       // Enable Clock Run
        ((0x00UL << CCU1_CLK_SPI_STAT_AUTO_Pos) & CCU1_CLK_SPI_STAT_AUTO_Msk) |        // Disable autoblocking
        ((0x00UL << CCU1_CLK_SPI_STAT_WAKEUP_Pos) & CCU1_CLK_SPI_STAT_WAKEUP_Msk); // Disable Wakeup
            //LPC_RGU->RESET_CTRL0
            LPC_SCU->SFSP3_6 |= 1; // MISO
            LPC_SCU->SFSP3_7 |= 1; // MOSI
            LPC_SCU->SFSP3_3 |= 1; // SCK
            LPC_SCU->SFSP3_8 |= 1; // SSEL
            LPC_SPI->CCR = 16;
            // Configure the SPI Module for Master Mode and X
            while( 1 )
                    LPC_SPI->DR = 0xA1;
  • Hello,
    i am dealing with exactly the same problem. Did you solve your problem? I would appreciate every help very much.
    Kind regards,
    Phil
