ST Libraries
I've had a rather complex problem with Keil uVision versions lately. I've begun working on some field-tested code developed for the STM32F105R8 in uVision using the ST libraries in Keil/ARM/INC/ST/STM32F10x/. I cannot say for sure which version of uVision this code was originally developed in, but it has been compiled, loaded and run successfully for some time now.
While trying to get uVision to recognize a ULINK2 controller, I tried to update uVision to v4.7. This led to thousands of compile errors, all related to conflicts between ST library files. In particular, it seems that stm32f10x.h tried to redefine a number of data types that were already defined in other libraries. I was able to remove most of these errors by removing that file from the STM32F10x folder, but now a number of datatypes that were frequently used in the code are not recognized, namely: uint8_t, uin16_t, uint32_t.
I understand that these datatypes can be changed with little impact on the functionality of the code. What I don't understand is why updating uVision would mess up existing code. Are the new ST libraries not backwards compatible? Does updating uVision without uninstalling it first mess up the included libraries? Is it even possible to really uninstall and remove uVision from your computer?
  • Just for reference, it seems that most of the conflicts come from two files, stm32f10x_type.h and stm32f10x_map.h, with stm32f10x.h. However, these files do not seem to have entirely duplicate data. Removing one or the others still causes errors because they actually #include each other inside themselves, and data types from all three are used in the code.
  • ST has evolved drivers and CMSIS support. Use the current libraries from ST, and path to the includes from within the new library (perhaps 3-6 directories if you set them up with the Utilities or EVAL boards), rather than let the compiler search it's own default paths, and old files. ST includes project templates for Keil, you should review how they are structured, both in terms of pre-processor defines, and include library search paths. This will give you far less head-aches.
  • Keil/ARM/INC/ST/STM32F10x/.
    that would be good if ST sent Keil an urgent e-mail every time they updated their software and Keil jumped at it and sent out a new release.
    The fact is that most "manufacturer supplied" software at the Keil site is hopelessly out of date
    THUS, always get "manufacturer software" from the manufacturers website
  • Or sometimes write own code or consider third-party code.
    Now and then, even manufacturer-supplied code can hold quite low standard.
