How to make interrupts work in LPC2138 using Proteus and Keil v4 compiler?
Hello, I am learning ARM processor using Keil uVision4 and simulating in proteus a LPC2138. I tried to make interrupt with timer0, the only result is the match pin toggling, but never enters inside the ISR. Please, can any body tell me what is wrong or mising?
#include <lpc21xx.h>
//global variables
  unsigned long cont = 0;
void wait (void)  {                                        /* wait function */
  long  d;
  for (d = 0; d < 10000; d++);                             /* only to delay for LED flashes */
void TIMER0_ISR(void) __irq
        cont++;
        cont &= 0x0ff;
        IO1CLR = 0x00ff0000;
        IO1SET = cont<<16;
        T0IR            |= 0x00000001;                  //Clear match 0 interrupt
        VICVectAddr = 0x00000000;                       //Dummy write to signal end of interrupt
#pragma ARM
int main (void)
  IODIR1 = 0x00FF0000;                                     // P1.16..23 defined as Outputs
        PINSEL0 |= 0x20000000;        //EINT1 en p0.14
        PINSEL0 |= 0x00000800;        //MAT0.1 en p0.5
        PINSEL0 |= 0x00000080;        //MAT0.0 en p0.3
        //timers
  VPBDIV = 0x00000001;                  // Configure the  VPB divi
  T0PR = 0x000003e8;                    //Load prescaler = 1000
  T0TCR = 0x00000002;                   //Reset counter and prescaler
  T0MCR = 0x00000003;                   //On match reset the counter and generate an interrupt
        T0MR0           = 0x000003e8;                   //match register = 1000
  T0EMR                 = 0x00000032;                   //complementa MAT0 y MAT1
  T0TCR                 = 0x00000001;                   //enable timer
  VICVectAddr0 = (unsigned long)TIMER0_ISR;                   /* Set Interrupt Vector in 0      */
  VICVectCntl0 = 0x20 | 0x04;                              /* Use it for Timer0 Interrupt    */
        VICIntEnable |=0x00000010;                               //habilitacion
        while (1) {}
Edit Post Reply Reply With Quote Multi-Quote Msg Report Post View Profile Private Message
