Hi, I'm trying to set up an SPI for an LPC1114. I don't have my slave chip just yet, so I just want to be able to read a clk of off PIO0_6, but I'm having a hard time doing this. This is my first time using MCUs in general, so I'm not too comfortable.
For some reason, I can't get any output to display, and I'm not sure what to try anymore. This is the code I have so far:
/* included libraries */ #include <stdio.h> #include "LPC11xx.h" //#include "ssp.h" /* SSP Status register */ #define SSPSR_TFE (0x1<<0) #define SSPSR_TNF (0x1<<1) #define SSPSR_RNE (0x1<<2) #define SSPSR_RFF (0x1<<3) #define SSPSR_BSY (0x1<<4) /* SSP CR1 register */ #define SSPCR1_LBM (0x1<<0) #define SSPCR1_SSE (0x1<<1) #define SSPCR1_MS (0x1<<2) #define SSPCR1_SOD (0x1<<3) /* FIFO Register size */ #define FIFOSIZE 8 /* macro definitions */ #define MY_PIO0_0 0x01 #define MY_PIO0_1 0x02 #define MY_PIO0_2 0x04 #define MY_PIO0_3 0x08 #define MY_PIO0_4 0x10 #define MY_PIO0_5 0x20 #define MY_PIO0_6 0x40 #define MY_PIO0_7 0x80 #define MY_PIO0_8 0x100 #define MY_PIO0_9 0x200 #define CS 0x00 #define SCLK 0x00 #define SDATA 0x00 void config_SSP(void) { uint8_t i, Dummy = Dummy; //enable clocks for the SSP LPC_SYSCON->PRESETCTRL |= (0x1<<0); LPC_SYSCON->SYSAHBCLKCTRL |= (1UL << 11); LPC_SYSCON->SSP0CLKDIV = 0xFF; //Orig clk is 3MHz?? LPC_IOCON->PIO0_8 &= ~0x07; //SSP I/O config LPC_IOCON->PIO0_8 |= 0x01; //SSP MISO LPC_IOCON->PIO0_9 &= ~0x07; LPC_IOCON->PIO0_9 |= 0x01; //SSP MOSI LPC_IOCON->SCK_LOC = 0x02; LPC_IOCON->PIO0_6 = 0x02; LPC_IOCON->PIO0_2 &= ~0x07; LPC_IOCON->PIO0_2 |= 0x01; //Set DSS data to 8-bit, Frame format SPI, CPOL = 0, CPHA = 0, and SCR is 7 LPC_SSP0->CR0 = 0x0707; //SSPCPSR clock prescale register, master mode, minimum divisor is 0x02 LPC_SSP0->CPSR = 0x2; for(i = 0 ; i < FIFOSIZE ; ++i) Dummy = LPC_SSP0->DR; //Master mode LPC_SSP0->CR1 = 0; LPC_SSP0->CR1 = SSPCR1_SSE; } void config_GPIO(void) { //enable clocks to GPIO block LPC_SYSCON->SYSAHBCLKCTRL |= (1UL << 6); //set port 0_7 to output (high current drain in LPC1114) LPC_GPIO0->DIR |= MY_PIO0_7; } void SPISend( uint8_t Radd, uint8_t Rval) { uint8_t Dummy=Dummy; Radd&=0x7F; /* Move on only if NOT busy and TX FIFO not full. */ while ( (LPC_SSP1->SR & (SSPSR_TNF|SSPSR_BSY)) != SSPSR_TNF ); LPC_SSP1->DR = Radd; //while ( (LPC_SSP1->SR & (SSPSR_BSY|SSPSR_RNE)) != SSPSR_RNE ); Dummy = LPC_SSP1->DR; while(!(LPC_SSP0->SR & SSPSR_BSY)); while ( (LPC_SSP1->SR & (SSPSR_TNF|SSPSR_BSY)) != SSPSR_TNF ); LPC_SSP1->DR = Rval; //while ( (LPC_SSP1->SR & (SSPSR_BSY|SSPSR_RNE)) != SSPSR_RNE ); while(!(LPC_SSP0->SR & SSPSR_BSY)); Dummy = LPC_SSP1->DR; return; } unsigned char SPIReceive(uint8_t Radd) { unsigned char SPIRECV; Radd|=0x80; //LPC_GPIO2->MASKED_ACCESS[(1<<SPI_CS)] = (0<<SPI_CS); // cs=0 LPC_SSP1->DR = Radd; while ( LPC_SSP1->SR & SSPSR_BSY ); LPC_SSP1->DR = 0xFF; while ( (LPC_SSP1->SR & (SSPSR_BSY|SSPSR_RNE)) != SSPSR_RNE ); SPIRECV = LPC_SSP1->DR; return SPIRECV; } /* MAIN!!!!!!! */ int main() { int i, j, tmp; //init GPIO and SSP SystemInit(); config_GPIO(); config_SSP(); while (1) { SPIReceive((uint8_t)tmp); //SPISend(j, j); //ledOn(); for (i = 0; i < 0x0007FFFF; i++) { } //ledOff(); for (i = 0; i < 0x0007FFFF; i++) { } j++; } }
I really appreciate your help :)
Just to clarify, I am reading the PIO0_6 pin through a scope, but all I get is a logical high, not a clock, as I should.
i have same problem, have you found the solution?
Br,
Norbert
