Setup heap on external RAM
Hi
I have a board with external RAM and I'm using it quite well, except that I wrote my own malloc and free, which works fine, but I rather use the malloc and free that comes with standard library, I know that wheel will be more reliable than the one I made.
Where is the linker script? I'm using uVision4 IDE and Keil as my compiler.
Basically I want to define heap in a different segment other than the internal RAM of the MCU.
If you can post me an example that will much appreciated.
Alejandro
  • Hi
    I went to the Project options (target) and defined an external RAM with start address and size. So the question now is how can I define that that RAM is for the heap segment, so standard lib does use it for malloc/free.
    Alejandro
  • Uncheck "Use Memory Layout from Target Dialog"
    Create a scatter file. Edit the default one
    ; *** Scatter-Loading Description File generated by uVision ***
    LR_IROM1 0x08000000 0x00040000  {    ; load region size_region
      ER_IROM1 0x08000000 0x00040000  {  ; load address = execution address
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
      RW_IRAM1 0x20000000 0x00018000  {  ; RW data
       .ANY (+RW +ZI)
      RW_IRAM2 0x20018000 0x00008000  {  ; Secondary Memory
       startup_xxx.o (HEAP) ; Object/Section directive, park HEAP in here
    startup_xxx.s, shouldn't need to change
    ; <h> Heap Configuration
    ;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
    ; </h>
    Heap_Size       EQU     0x00000200
                    AREA    HEAP, NOINIT, READWRITE, ALIGN=3
    __heap_base
    Heap_Mem        SPACE   Heap_Size
    __heap_limit
  • Thanks much
    This is my file, it worked great!!!
    LR_IROM1 0x08000000 0x00100000 { ; load region size_region ER_IROM1 0x08000000 0x00100000 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) } RW_IRAM1 0x20000000 0x00020000 { ; RW data .ANY (+RW +ZI) } ; External RAM ; Used for mallocs, mainly for the file system/nand media driver RW_RAM1 0x60000000 0x00200000 { ; Secondary Memory .ANY (HEAP) ; Object/Section directive, park HEAP in here }
  • Sorry about the formatting, fixed showing correct below.
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
       .ANY (+RW +ZI)
      ; External RAM
