LPC 2148: Fetching data from uart and displaying that on LCD
Hey,
I have a sensor which sends ASCII data.
I want to save that data in the RBR register of UART and then display it on the LCD
I am here posting the code for the same but i am not getting any display on LCD.
Kindly help me out in the same.
#include<stdio.h>
#include<lpc214x.h>
#include<string.h>
#define TEMT (1<<6)
#define LINE_FEED 0xA
#define CARRIAGE_RET 0xD
typedef unsigned char uchar ;
typedef unsigned int  uint ;
typedef unsigned long ulong;
#define DATA_PORT() IO0SET=(1<<16)                 //Function to select data port on LCD
#define EN_HI() IO0SET=(1<<18)                     //Function to Enable LCD
#define COMMAND_PORT() IO0CLR=(1<<16)       //Function to select command port on LCD
#define WRITE_DATA() IO0CLR=(1<<17)                 //Function to select write operation on LCD
#define EN_LOW() IO0CLR=(1<<18)                     //Function to disable LCD
/*************** System Initialization ***************/
void Initialize()
/* Initialize Pin Select Block for Tx and Rx */
PINSEL0=0x00050005;
/* Enable FIFO's and reset them */
U0FCR=0x7;
/* Set DLAB and word length set to 8bits */
U0LCR=0x83;
/* Baud rate set to 9600 */
U0FDR=0x00000075;
U0DLL=0x39;
U0DLM=0x0;
/* Clear DLAB */
U0LCR=0x3;
U1FCR=0x7;
U1LCR=0x83;
U1FDR=0x00000075;
U1DLL=0x39;
U1DLM=0x0;
/* Clear DLAB */
U1LCR=0x3;
 // Recieve data from UART1(sensor)
char data[16];
int LSR;
    char Recieve(void )
        LSR = U1LSR;       //* Read LSR(Line Status Register) Register *
                while ( !(U1LSR & 0x01) );  //* Check Whether Data is Recieved *
                                    //* i.e. Check RDR(Read Data Ready) interrupt.*
                                                  //* If Yes then get data From RBR(Recive Buffer Register).*
                data[16] = U1RBR; //Data Recieved and saved in RBR
                //MsDelay( 50 );
                return( 0 );
 void Delay(unsigned char j)    // Delay
 unsigned int  i;
 for(;j>0;j--)
  for(i=0; i<60000; i++);
void LCD_Command(unsigned int data)                       //This function is used to send LCD commands
 unsigned int temp=0;
 EN_LOW();
 COMMAND_PORT();
 WRITE_DATA();
 temp=data;
 IO0PIN&=0xFF87FFFF;
 IO0PIN|=(temp & 0xF0) << 15;
 EN_HI();
 EN_LOW();
 temp=data & 0x0F;
 IO0PIN&=0xFF87FFFF;
 IO0PIN|=(temp) << 19;
 EN_HI();
 EN_LOW();
 Delay(10);
void LCD_Data(unsigned int data)                   //This function is used to send data to LCD
 EN_LOW();
 DATA_PORT();
 WRITE_DATA();
 temp=data;
 IO0PIN&=0xFF87FFFF;
 EN_HI();
 EN_LOW();
 temp=data & 0x0F;
 IO0PIN&=0xFF87FFFF;
 EN_HI();
 EN_LOW();
 Delay(5);
void LCD_Init()
 LCD_Command(0x20);
 LCD_Command(0x28);
 LCD_Command(0x0C);
 LCD_Command(0x06);
void LCD_String(unsigned char *data)
 while(*data)
  LCD_Data(*data);
  data++;
          void main(void)
    while(!(U1LSR & 0x01));
        Initialize();
    Recieve();
 PINSEL0 = 0x00000000;          // Enable GPIO on all pins
 PINSEL1 = 0x00000000;
 PINSEL2 = 0x00000000;
 Delay(20);
 IO0DIR = (1<<22) | (1<<21) | (1<<20) | (1<<19) | (1<<18) | (1<<17) | (1<<16);                // Set P0.16, P0.17, P0.18, P0.19, P0.20, P0.21, P0.22 as Output
        LCD_Init();
        LCD_Command(0x01);              //Clear LCD
    Delay(20);
    LCD_Command(0x80);     // Position Line 1
    LCD_String(&data[16]);
        while(1)
  • "I am here posting the code for the same but i am not getting any display on LCD."
    And you then directly did a bit of debugging, to figure out if you have an issue with receiving data from the UART, or if you do receive good data but fails to print to the LCD. And what was the result of that debugging?
