RTX OS_ERR_FIFO_OVF
I am using the STM32F207 (Cortex-M3) device with MDK 4.50. I have an ISR function which calls isr_evt_set() to send a “Tick” event when a 1ms h/w timer tick occurs. A task calls os_evt_wait_and() and waits indefinitely for the “Tick” event. When the event arrives it does some processing and then waits for the next “Tick” event.
This all works OK until I set a breakpoint. When I hit F5 to continue code execution I get an os_error() with err_code 2 (OS_ERR_FIFO_OVF). This implies that the ISR FIFO queue buffer has overflowed. This does not happen at any other time accept when continuing after a breakpoint. I have changed the OS_FIFOSZ size from 16 to 96 but this made no difference.
I do not get this problem if I run the same code on an STR91x (ARM9).
Any ideas?
