USB host
Hello Sir,
I am working on USB host using LPC2468. I am facing a problem when i try to create 6 different file it creates 5 files on pendrive 6th file is not creating my code is like that
for(file_no =1;file_no<=6;file_no++)
files_on_pendrive();
void files_on_pendrive(void){
switch(file_no){
case 1:
           cashier_dbase();
           break;
case 2:
           tax_dbase();
           break;
case 3:
           billsumm_dbase();
           break;
case 4:
           crd_trans_dbase();
           break;
case 5:
           bill_copy_dbase();
           break;
case 6:
           pagewise_dbase();
           break;
in the above code each switch case creates a file but case6 is not creating the file if i place case 5 function in place of case6 function then again case6 is not creating a file
what,s the reason behind it.
  • Exactly what have this with "USB Host" to do?
  • Sir,
    I know usb host has no role in this .I think you didn,t understand the question.
    Anyway thanks for your kind support
  • I think I did.
    Your first post specifically said you were working on a USB host.
    But your issue don't seem to relate to any USB host.
    So then the issue is that you haven't really given us any information at all.
    You create files, you say. Using what file system? Saving to what media? Doing what debugging?
    I think you haven't understood the question yourself, since you haven't given us anything to work on.
    Maybe, just maybe the file system library supports 5 open files, and you have forgotten to close the current file before you start creating the next file. So when you try to create file number 6, you get a failure. By the way - don't you log failures? Are there absolutely zero function calls that fails?
  • Sir,I apologize for this mistake.
    I tell you each and everything briefly
    1 i am using FAT32 file system ,Try to create file on pendrive, As far as debugging is concerned when I debug through case 6 in source code which i post you in last thread every thing is ok each and every function is performing their operation as like in other cases.
    2 I am closing each file after creating it and writing data to it.
    3 I want to know how to modify the file system so that it supports more than 5 open files.
    One more thing I am creating file name with date and time append to it as shown below
    sprintf(filename, "CASHIER-%d-%02d-%02d-%02d-%02d.RTF", RTC_DOW, RTC_MONTH, RTC_YEAR,RTC_HOUR,RTC_MIN);
              host_write(filename,tot_bytes, pac_nob);
    void host_write(UWORD8 *file_name,UWORD32 tot_byte2_write,UWORD16 pac_nob1)
    UWORD16  host_nob,host_pac_nob;
    SWORD32  fdw;
    UWORD32  write_size;
    UWORD32  bytes_written,tot_bytes_written;
    UWORD16  host_var0;
    write_size=tot_byte2_write;
    host_pac_nob =pac_nob1;
        fdw = FILE_Open(file_name, RDWR);
        if (fdw > 0)
                 tot_bytes_written = 0;
                             if(tot_byte2_write> MAX_BUFFER_SIZE)
                             host_nob=MAX_BUFFER_SIZE;
                             else
                             host_nob=tot_byte2_write;
                                   if(ext_pac_nob==0)
                                        host_var0 =0;
                                       else
                                        host_var0 =13;
                                       for(; host_var0<host_nob;host_var0++)
                                                    if(host_pac_nob==0){
                                                       *UserBuffer++ = s_chksum >> 8;
                                   *UserBuffer++ = (UWORD8) s_chksum;
                                   *UserBuffer++ = 0x64;
                                                       break;
                                              else
                                                      trf_time_srch();
                                                  host_pac_nob--;
                        UserBuffer-=host_nob;
                do {
                                    if(write_size> MAX_BUFFER_SIZE)
                    bytes_written = FILE_Write(fdw, UserBuffer,MAX_BUFFER_SIZE);
                                    else
                                    bytes_written = FILE_Write(fdw, UserBuffer,write_size);
                    tot_bytes_written += bytes_written;
                                    write_size-=bytes_written;
                                    if(write_size!=0 && write_size<MAX_BUFFER_SIZE)
                                            for(host_var0=0; host_var0<write_size;host_var0++)
                                   *UserBuffer++ = (UWORD8) s_chksum;;
                                                       break;
                                                    else {
                                                       trf_time_srch();
                                                       host_pac_nob--;
                                      UserBuffer-= write_size;
                                    else
                                    if(write_size!=0)
                                            for(host_var0=0; host_var0<MAX_BUFFER_SIZE;host_var0++)
                                                  trf_time_srch();
                                          host_pac_nob--;
                                       UserBuffer-=MAX_BUFFER_SIZE;
                                while (write_size!=0);
                                    fl_host_lnk =FALSE;
                    FILE_Close(fdw);
                                    else{
                                    return;
    This host_write function is called in all 6 cases.
    Sir when i remove date and time from file name I am able to create 6 files successfully.
    What,s the reason behind it.
