USB descriptor for stereo recorder
Hi all,
I am implementing a stereo recroder application. The application should send the recorded data
over USB to host application (e.g. Audacity,).
I succeeded to make the recorder to "record" propperly and now I am stuck at USB communcation and specifically at USB descriptor.
I started from the example provided in Audio spec appendix B "USB microphone" (page 105) and I am trying to make it stereo channel and 48KHz but I get at windows I got error code = 10.
Here below the descriptor. Can you tell me where I can find the error?
u8 Descritpr[100] =
{ 0x09, /* bLength */
USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType */
LOBYTE(AUDIO_CONFIG_DESC_SIZE), /* wTotalLength */
HIBYTE(AUDIO_CONFIG_DESC_SIZE),
0x02, /* bNumInterfaces */
0x01, /* bConfigurationValue */
0x00, /* iConfiguration */
0x80, /* bmAttributes BUS Powred*/
0x0A, /* bMaxPower = 100 mA*/
/* USB Speaker Standard AC Interface descriptor */
0x09,
0x04,
0x00,
0x00,
0x00,
0x01,
0x01,
0x00,
0x00,
/* Class specific AC interface descriptor */ 0x09,
0x24,
0x01,
0x00,/* bcdADC */
0x01,
0x1E,/* wTotalLength */
0x00,
0x01, /* bInCollection */
0x01, /* baInterfaceNr(1) */
/* Input Terminal Descriptor */
0x0C, /* bLength */
0x24, /* bDescriptorType */
0x02, /* bDescriptorSubType */
0x01, /* bTerminalID */
0x01, /* wTerminalType */
0x02, /* wTerminalType */
0x00, /* bAssocTerminal */
0x01, /* bNrChannels */
0x00, /* wChannelConfig */
0x00, /* iChannelName */
0x00, /* iTerminal */
/* Output Terminal Descriptor */
0x09, /* bLength */
0x03, /* bDescriptorSubType */
0x02, /* bTerminalID */
/* Standard AS Interface Descriptor (Alt. Set. 0) */
0x09, /* bLength */
0x04, /* bDescriptorType */
0x01, /* bInterfaceNum */
0x00, /* bAlternateSetting */
0x00, /* bNumEndpoints */
0x01, /* bInterfaceClass */
0x02, /* bInterfaceSubClass */
0x00, /* bInterfaceProtocol */
0x00, /* iInterface */
/* Standard AS Interface Descriptor (Alt. Set. 1) */
0x09, /* bLength */
0x01, /* bAlternateSetting */
0x01, /* bNumEndpoints */
/* Class specific AS General Interface Descriptor */
0x07, /* bLength */
0x01, /* bDescriptorSubType */
0x02, /* bTerminalLink */
0x01, /* bDelay */
0x01, /* wFormatTag */
0x00, /* wFormatTag */
/* Foramt Type Descriptor */
0x0B,
0x24,
0x02,
0x01,
0x01,
0x02,
0x10,
0x01,
0x40,
0x1F,
0x00,
/* Endpoint Descriptor */
0x09, /* bLength */
0x05, /* bDescriptorType */
0x83, /* bEndpointAddress */
0x01, /* bmAttributes */
0x10, /* wMaxPacketSize */
0x00, /* wMaxPacketSize */
0x01, /* bInterval */
0x00, /* bRefresh */
0x00, /* bSynchAddress */
/* Audio Data Endpoint Descriptor */
0x07,
0x25,
0x01,
0x00,
0x00,
0x00,
0x00,
  • /* Input Terminal Descriptor */
    0x0C, /* bLength */
    0x01, /* bNrChannels */      // <---- 0x02,  // two channels
    0x00, /* wChannelConfig */   // <---- 0x03,  // left front / right front
    /* Format Type Descriptor */
    0x0B,
    0x24,
    0x02,
    0x01,
    0x01,     /* bNrChannels */  // <---- 0x02, //Two channels
    0x02
    0x10,
    0x01,
    0x40,
    0x1F,
    0x00,
    0x09, /* bLength */
    0x01, /* bmAttributes */     // <---- 0x05,  // isoc, Asynchronous
    0x10, /* wMaxPacketSize */   // <---- 0x24,  // 36 bytes (2 bytes/ch * 2 ch * (8 + 1) samples / frame)
    Tsuneo
  • Ah, missed at these requirement,
    Ah, recorded data, instead of "real-time" microphone. Then Synchronous is better.
    0x0C, /* bLength */
    0x0B,
    0x24,
    0x02,
    0x01,
    0x02
    0x10,
    0x01,
    0x40,     /*tSamFreq[0] */   // <---- 0x80,  // 48 kHz
    0x1F,                        // <---- 0xBB,
    0x00,
    0x09, /* bLength */
    0x01, /* bmAttributes */     // <---- 0x0D,  // isoc, Synchronous
    0x10, /* wMaxPacketSize */   // <---- 0xC0,  // 192 bytes (2 bytes/ch * 2 ch * 48 samples / frame)
    0x07,
    0x25,
    0x01,
    0x00,
    0x00, /* bLockDelayUnits */  // <---- 0x02,  // Decoded PCM samples
    0x00,
    0x00,
    Tsuneo
