How to make the assembler pre process the .S file before assembling under Keil MDK?
With other tools , assembler auto pre process the .S , but Keil MDK does not.
how to set?
code like :
#define ENTRY(name) /
   .globl name; /
   ALIGN; /
   name:
ENTRY(__udivsi3)
will warning like this
lib1funcs.S(44): error: junk at end of line, first unrecognized character is '/'
 lib1funcs.S(45): error: bad instruction 'align'
 lib1funcs.S(45): error: junk at end of line, first unrecognized character is '/'
 lib1funcs.S(216): error: bad instruction 'entry(__udivsi3)'
Tool Version Numbers: Toolchain: MDK-Lite Version: 4.71.0.0 Toolchain Path: C:\Program Files (x86)\GNU Tools ARM Embedded\4.7 2012q4\bin C Compiler: GCC.Exe Assembler: AS.Exe Linker/Locator: LD.Exe Librarian: AR.Exe Hex Converter: OBJCOPY.Exe
