Use MDK libraries with gcc?
I am trying to use the MDK libraries (TCPnet) in an application that I build using gcc. The ld linker complains about the format of the TCP_CM3.lib file: "could not read symbols: File format not recognized".
Does anyone know about how to fix this?
Is it possible to convert the file format in some way?
/Peter
  • Yes. Get a TCP/IP library compiled using the same gcc as you build the rest of the project with.
    Or get the source code for a TCP/IP library and build.
    In theory, you could buy the source from Keil - but the license would probably not allow you to use that source with gcc so you better then also use a commercial Keil license for the compiler+linker in which case the Keil library file will be usable without a recompile.
  • So what you are saying is that if I want to stay with the KEIL MDK, and their TCP stack I should switch to their compiler and leave gcc?
    I found the CMSIS-API release of the RTX part of the MDK. It has a gcc compiled lib. So I hoped there should be a way to get a gcc version of the other MDK parts too.
    I gave LwIP a shot a while ago, but I found the MDK/TCP package easier to work with.
  • Yes, but look at the license for CMSIS port of RTX - so it's logical that you find a build with a free compiler.
    The Keil TCP/IP stack isn't free.
