I had create a function that use __asm{ NOP NOP NOP NOP}; which it's work correctly on older version (about 4.0x). but It's problem in 4.2x version like this ": error: #1083: Inline assembler syntax error"
Does anyone has new Inline Assembler Syntax ?? Please told me...
Thank you
http://www.keil.com/support/man/docs/armcc/armcc_Cihiggjc.htm
Inline assembly language syntax with the __asm keyword in C and C++
Thank you for your reply I used to try by follow your link. But I has same error....
__asm("NOP NOP NOP NOP"); and __asm{NOP NOP NOP NOP}
Does anyone has anyidea??
Hello Tihnov Poo,
instead of using inline assembler you can use the inrtinsic __nop().
__nop();__nop();__nop();__nop();
Best Regards, Martin Guenther
Thank you It's work...
but I don't know why new version isn't support inline assembler old version..
thank you
