error 123: AGDI: invalid operation when using Display command
Hi all,
When I use CooCox ColinkEx and Keil 4.23 to debug STM32F407, it seems that there're problems with AGDI.
When the CPU is set as STM32F407IG / Cortex-M4 FPU:
If the CPU is halted, the memory window can not show any address data, it is blank. And I execute the display command "D 0x0, 0x100" in command window gives "error 123: AGDI: invalid operation".
When the CPU is set as Cortex-M4:
If the CPU is halted, the memory window works fine. And I execute the display command "D 0x0, 0x100" in command window gives the memory result.
I compared the two target in the blinky.uvproj, I find the problem depends on the FPU2 option in the Cpu tag.
when the Cpu like:
<Cpu>IRAM(0x20000000-0x2001FFFF) IRAM2(0x10000000-0x1000FFFF) IROM(0x8000000-0x80FFFFF) CLOCK(25000000) CPUTYPE("Cortex-M4") FPU2</Cpu>
Then the memory window and display command can not work.
when the Cpu like:
<Cpu>IRAM(0x20000000-0x2001FFFF) IRAM2(0x10000000-0x1000FFFF) IROM(0x8000000-0x80FFFFF) CLOCK(25000000) CPUTYPE("Cortex-M4")</Cpu>
Both the memory window and display command work fine.
Is there any workaround for this problem ?
Here is a similar problem: www.segger2.com/index.php
  • This looks like a problem with your CoLinkEx driver. Your target processor is a Cortex-M4 with FPU, however the specification of the CoLinkEx reads that it supports Cortex-M0 and Cortex-M3 targets only. I assume that the debugger is not capable of handling the read and write of FPU registers. The failure of the memory display is only a side effect. As long as you do not make use of the FPU, it is safe to omitt the FPU2 option.
